Full Version: mkv playback problem msi e350ia-e45
when i play some mkv files video stutters a little, for example the movie HUGO.
General
Unique ID : 214812534229245002144553480390193462005 (0xA19B63A347471B02B28153B582203AF5)
Complete name : D:\Hugo (2011) x264 1080p DTS & DD 51 NL Subs Made By ~ SRT ~\Hugo (2011) 1080P SimplyReleases Toppers\Hugo (2011) 1080P SimplyReleases Toppers.mkv
Format : Matroska
Format version : Version 2
File size : 9.14 GiB
Duration : 2h 6mn
Overall bit rate : 10.4 Mbps
Encoded date : UTC 2012-02-18 12:54:36
Writing application : mkvmerge v5.2.1 ('A Far Off Place') built on Jan 2 2012 23:21:10
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 8 399 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Original frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.169
Writing library : x264 core 120 r2164 da19765
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8399 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
mediaplayer classic homecinema with coreavc or xbmc 11.0 eden or nighly builds , video stutters almost every 20 seconds for only one second.
harddisk light is flashing a lot, cpu load is 40%. (mediaplayer classic)
harddisk light is flashing normal and cpu load between 7 and 12%
msi has a AMD e350 processor with amd hd6310 shared video card 512MB, 4 GB ram
Harddisk is a 2,5" 1 TB samsung 5400 rpm
i have the newest amd video drivers installed and directx
do i have to tweak something( cocec?), i don't know how to that in xmbc.
or is the sytem not powerful enough? the same file plays perfectly on my notebook (i7)
i have found the problem myself
go to video settings
playback
adjust display refresh rate to match video enabled
no video stuttering anymore ;-) in xbmc
now i have to search for same settings in mediplayer classic
