2012-10-30, 21:05
(2012-10-30, 20:56)roach9 Wrote: [ -> ]annnnd i switched back.
Yes, Openelec is perfect for certain people!
At least you tried some alternatives.
uNi
(2012-10-30, 21:34)Bram77 Wrote: [ -> ](2012-10-30, 20:56)roach9 Wrote: [ -> ]annnnd i switched back.
Maybe you could provide me with some feedback? What do you miss in this installation compared to OpenElec?
(2012-10-27, 00:49)uNiversal Wrote: [ -> ]@Bram77 libcec is part of the xvba packages it pumps in auto, one less to do! Feature added already.
Script installs stable xbmc, but it could offer cutting edge as well?
While your making a lists the IONHT CIR can be fixed as well , Link in my signature.
Th mini xinit upstart scrip is the way to go, problem is that if you press exit on power menu xbmc restarts, instead of going to terminal (no biggie)
Ill have a look at script tomorrow for anything that may have been left out, typos etc.
Im sure I have posts that just too much info... lol.
uNi
[3032315.355] (++) Using config file: "/storage/.config/xorg.conf"
[3032318.149] (II) NVIDIA(GPU-0): Display (ONKYO Corporation TX-SR705 (DFP-0)) does not support
[3032318.149] (II) NVIDIA(GPU-0): NVIDIA 3D Vision stereo.
[3032318.154] (II) NVIDIA(0): NVIDIA GPU GeForce GT 520M (GF119) at PCI:2:0:0 (GPU-0)
[3032318.154] (--) NVIDIA(0): Memory: 524288 kBytes
[3032318.154] (--) NVIDIA(0): VideoBIOS: 75.19.0a.00.09
[3032318.154] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[3032318.154] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[3032318.156] (--) NVIDIA(0): Valid display device(s) on GeForce GT 520M at PCI:2:0:0
[3032318.156] (--) NVIDIA(0): CRT-0
[3032318.156] (--) NVIDIA(0): ONKYO Corporation TX-SR705 (DFP-0) (connected)
[3032318.156] (--) NVIDIA(0): DFP-1
[3032318.156] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[3032318.156] (--) NVIDIA(0): ONKYO Corporation TX-SR705 (DFP-0): 165.0 MHz maximum pixel clock
[3032318.156] (--) NVIDIA(0): ONKYO Corporation TX-SR705 (DFP-0): Internal Single Link TMDS
[3032318.159] (WW) NVIDIA(GPU-0): The EDID for ONKYO Corporation TX-SR705 (DFP-0) contradicts
[3032318.159] (WW) NVIDIA(GPU-0): itself: mode "1920x1080" is specified in the EDID;
[3032318.159] (WW) NVIDIA(GPU-0): however, the EDID's valid VertRefresh range (49.000-61.000
[3032318.159] (WW) NVIDIA(GPU-0): Hz) would exclude this mode's VertRefresh (24.0 Hz);
[3032318.159] (WW) NVIDIA(GPU-0): ignoring VertRefresh check for mode "1920x1080".
[3032318.160] (WW) NVIDIA(GPU-0): The EDID for ONKYO Corporation TX-SR705 (DFP-0) contradicts
[3032318.160] (WW) NVIDIA(GPU-0): itself: mode "1920x1080" is specified in the EDID;
[3032318.160] (WW) NVIDIA(GPU-0): however, the EDID's valid VertRefresh range (49.000-61.000
[3032318.160] (WW) NVIDIA(GPU-0): Hz) would exclude this mode's VertRefresh (25.0 Hz);
[3032318.160] (WW) NVIDIA(GPU-0): ignoring VertRefresh check for mode "1920x1080".
[3032318.160] (WW) NVIDIA(GPU-0): Hz) would exclude this mode's VertRefresh (30.0 Hz);
[3032318.162] (==) NVIDIA(0):
[3032318.162] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[3032318.162] (==) NVIDIA(0): will be used as the requested mode.
(2012-10-31, 05:15)puntloos Wrote: [ -> ]Followed this guide on a zotac zbox ID80 (nvidia GPU, not ION though) it seems to work in principle:
And I don't have a black screenCode:[3032315.355] (++) Using config file: "/storage/.config/xorg.conf"
(2012-10-31, 05:15)puntloos Wrote: [ -> ]But the log gives me a ton of errors. Some relevant sounding snippets:
Code:snip
(2012-10-31, 05:58)uNiversal Wrote: [ -> ]You're correct.. I could put it in /etc too, but given that Openelec suggests putting additional files there I figured ..(2012-10-31, 05:15)puntloos Wrote: [ -> ]Followed this guide on a zotac zbox ID80 (nvidia GPU, not ION though) it seems to work in principle:
That's a openelec path, what's t doing in here? the xorg is placed in /etc/X11/xorg.conf Not anywhere else kthx
Quote:Sorry can you rephrase? Are you saying the error needs to be fixed?(2012-10-31, 05:15)puntloos Wrote: [ -> ]But the log gives me a ton of errors. Some relevant sounding snippets:There's relevant error to worry about
Code:snip
Quote: see if you follow this up tune yourself upFollowed that to the letter, with the only exception of where I put xorg.conf. Maybe the system is mixing 2 xorg.conf's now but other than that..
Quote:Dont mix openelec and minimal ubuntu, as paths are not same, this is nothing like openelec.Welllll.. the only thing that I'm trying to do is feed the nvidia driver a different configfile. I don't think mixing that part is too crazy..
(2012-10-31, 12:51)puntloos Wrote: [ -> ]You're correct.. I could put it in /etc too, but given that Openelec suggests putting additional files there I figured ..
(2012-10-31, 12:51)puntloos Wrote: [ -> ]Sorry can you rephrase? Are you saying the error needs to be fixed?
The error sounds like the Onkyo device is saying that it doesn't support 1080p@24 but it certainly does..
(2012-10-31, 12:51)puntloos Wrote: [ -> ]Followed that to the letter, with the only exception of where I put xorg.conf. Maybe the system is mixing 2 xorg.conf's now but other than that..
(2012-10-31, 12:51)puntloos Wrote: [ -> ]Welllll.. the only thing that I'm trying to do is feed the nvidia driver a different configfile. I don't think mixing that part is too crazy..
kthx +2
(2012-10-31, 09:38)illiac4 Wrote: [ -> ]Really nice script. Will try it on lenovo q180.
As an option maybe also some tools like:
- transmission
- boblight
- couchpotato
- sickberad
- samba
Is avahi already included for airplay?
How does your script handle ati drivers update? Will they auto update or. is it possible to hold the updates and manually execute them?
