2013-01-11, 18:12
I installed network Manager yesterday to be able to configure my wireless via xbmc to find out that it disables my usb-cec on build. Has anyone experience this, and if so is there a solution?
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
Setting up linux-image-3.5.0-19-generic (3.5.0-19.30) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-3.5.0-19-generic
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/dkms 3.5.0-19-generic /boot/vmlinuz-3.5.0-19-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.5.0-19-generic /boot/vmlinuz-3.5.0-19-generic
update-initramfs: Generating /boot/initrd.img-3.5.0-19-generic
^CFailed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.5.0-19-generic.postinst line 1010.
dpkg: error processing linux-image-3.5.0-19-generic (--configure):
subprocess installed post-installation script returned error exit status 2
Setting up linux-libc-dev:amd64 (3.5.0-21.32) ...
Setting up libshairport1:amd64 (1:1.2.1~git20121216.16395d8-0~ppa1~quantal) ...
dpkg: dependency problems prevent configuration of linux-image-extra-3.5.0-19-generic:
linux-image-extra-3.5.0-19-generic depends on linux-image-3.5.0-19-generic; however:
Package linux-image-3.5.0-19-generic is not configured yet.
dpkg: error processing linux-image-extra-3.5.0-19-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-image-3.5.0-19-generic; however:
linux-image-generic depends on linux-image-extra-3.5.0-19-generic; however:
Package linux-image-extra-3.5.0-19-generic is not configured yet.
dpkg: error processing linux-image-generic (--configure):
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic; however:
Package linux-image-generic is not configured yet.
dpkg: error processing linux-generic (--configure):
Setting up xbmc-bin (2:12.0~git20121223.0918-rc2-2quantal) ...
Setting up libglib2.0-0:amd64 (2.34.1-1ubuntu1) ...
Setting up xbmc (2:12.0~git20121223.0918-rc2-2quantal) ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for python-support ...
Errors were encountered while processing:
linux-image-generic
linux-generic
xbmc@xbmc:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages have been kept back:
linux-headers-generic linux-image-generic
The following packages will be upgraded:
gnupg gpgv memtest86+ mountall python3-dbus python3-distupgrade
ubuntu-release-upgrader-core ufw xbmc xbmc-bin
10 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
4 not fully installed or removed.
Need to get 37.5 MB of archives.
After this operation, 1,112 kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Get:1 http://us.archive.ubuntu.com/ubuntu/ quantal-updates/main mountall amd64 2.42ubuntu0.3 [68.8 kB]
Get:2 http://ppa.launchpad.net/wsnipex/xbmc-xvba/ubuntu/ quantal/main xbmc all 2:12.0~git20130104.1024-rc3-0quantal [22.2 MB]
Get:3 http://us.archive.ubuntu.com/ubuntu/ quantal-updates/main gpgv amd64 1.4.11-3ubuntu4.1 [185 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu/ quantal-updates/main gnupg amd64 1.4.11-3ubuntu4.1 [807 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu/ quantal-updates/main memtest86+ amd64 4.20-1.1ubuntu2.1 [285 kB]
Get:6 http://us.archive.ubuntu.com/ubuntu/ quantal-updates/main python3-dbus amd64 1.1.1-1ubuntu0.1 [101 kB]
Get:7 http://us.archive.ubuntu.com/ubuntu/ quantal-updates/main ubuntu-release-upgrader-core all 1:0.190.5 [27.9 kB]
Get:8 http://us.archive.ubuntu.com/ubuntu/ quantal-updates/main python3-distupgrade all 1:0.190.5 [142 kB]
Get:9 http://us.archive.ubuntu.com/ubuntu/ quantal-updates/main ufw all 0.33-0ubuntu2.1 [161 kB]
Get:10 http://ppa.launchpad.net/wsnipex/xbmc-xvba/ubuntu/ quantal/main xbmc-bin amd64 2:12.0~git20130104.1024-rc3-0quantal [13.5 MB]
Fetched 37.5 MB in 36s (1,025 kB/s)
Preconfiguring packages ...
(Reading database ... 90260 files and directories currently installed.)
Preparing to replace mountall 2.42ubuntu0.2 (using .../mountall_2.42ubuntu0.3_amd64.deb) ...
Unpacking replacement mountall ...
Preparing to replace gpgv 1.4.11-3ubuntu4 (using .../gpgv_1.4.11-3ubuntu4.1_amd64.deb) ...
Unpacking replacement gpgv ...
Processing triggers for man-db ...
Processing triggers for ureadahead ...
Setting up gpgv (1.4.11-3ubuntu4.1) ...
Preparing to replace gnupg 1.4.11-3ubuntu4 (using .../gnupg_1.4.11-3ubuntu4.1_amd64.deb) ...
Unpacking replacement gnupg ...
Processing triggers for install-info ...
Setting up gnupg (1.4.11-3ubuntu4.1) ...
Preparing to replace memtest86+ 4.20-1.1ubuntu2 (using .../memtest86+_4.20-1.1ubuntu2.1_amd64.deb) ...
Unpacking replacement memtest86+ ...
Preparing to replace python3-dbus 1.1.1-1 (using .../python3-dbus_1.1.1-1ubuntu0.1_amd64.deb) ...
Unpacking replacement python3-dbus ...
Preparing to replace ubuntu-release-upgrader-core 1:0.190.4 (using .../ubuntu-release-upgrader-core_1%3a0.190.5_all.deb) ...
Unpacking replacement ubuntu-release-upgrader-core ...
Preparing to replace python3-distupgrade 1:0.190.4 (using .../python3-distupgrade_1%3a0.190.5_all.deb) ...
Unpacking replacement python3-distupgrade ...
Preparing to replace ufw 0.33-0ubuntu2 (using .../ufw_0.33-0ubuntu2.1_all.deb) ...
Unpacking replacement ufw ...
Preparing to replace xbmc 2:12.0~git20121223.0918-rc2-2quantal (using .../xbmc_2%3a12.0~git20130104.1024-rc3-0quantal_all.deb) ...
Unpacking replacement xbmc ...
Preparing to replace xbmc-bin 2:12.0~git20121223.0918-rc2-2quantal (using .../xbmc-bin_2%3a12.0~git20130104.1024-rc3-0quantal_amd64.deb) ...
Unpacking replacement xbmc-bin ...
Processing triggers for hicolor-icon-theme ...
Running depmod.
(2013-01-11, 20:13)ozzyman778 Wrote: [ -> ]<snipped>
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:ubuntu-x-swat/x-updates
sudo add-apt-repository ppa:wsnipex/xbmc-xvba
sudo apt-get update
sudo apt-get install nvidia-current
sudo apt-get install xbmc
sudo usermod --group adm,sudo,cdrom,audio,video,plugdev,fuse,vboxusers xbmc
sudo adduser xbmc users
(2013-01-11, 20:24)uNiversal Wrote: [ -> ]Whats this got to do with script?
Your upgrading Linux as well why?
uNi
(2013-01-11, 20:34)uNiversal Wrote: [ -> ]er no you guys are definitely doing something wrong!
uNi
(2013-01-11, 19:41)uNiversal Wrote: [ -> ]ctrl+alt+F1 or F2 and F7 to get back
No, exit doesn't work as intended, idk why and honestly doesn't matter since the above works and most ppl use putty to do stuff.
uNi
uNi
sudo restart xbmc
or
sudo start xbmc
(2013-01-12, 00:41)Bram77 Wrote: [ -> ]I hope I understand correctly what the problem is here....
During the installation using the script you'll be asked if you want to enable automatic updates. This can be risky because you might turn off the machine while an update process is active in the background. In most cases this doesn't really matter. It will solve itself. But in some cases it might corrupt your apt cache or even you kernel installation. Maybe that's what has happened in these cases?
