Full Version: Cycling through grouplists
Aaand stuck.
I have a group with 5 grouplists. And 2 buttons, 1 for up and 1 for down.
These buttons need to cycle through the visibility of those grouplists. Only one grouplist can be visible at a time.
And i can't use hiddenfocus. Or check against another list control. I tried something with toggling skin settings but they don't seem flexible enough.
I assume this is where variables come in? But i could not find an example like this.
Help is much appreciated.
Conditional OnUp and OnDown controls?
you could use
<onclick condition="Stringcompare(Window.Property(VisibleGrouplist),5) | IsEmpty(Window.Property(VisibleGrouplist))">SetProperty(VisibleGrouplist,1)</onclick>
<onclick condition="Stringcompare(Window.Property(VisibleGrouplist),1)">SetProperty(VisibleGrouplist,2)</onclick>
<onclick condition="Stringcompare(Window.Property(VisibleGrouplist),2)">SetProperty(VisibleGrouplist,3)</onclick>
for button 1 and the same in the other direction for button 2.
for grouplist visibilty conditions you then use stringcompare(Window.Property(VisibleGrouplist),1) etc.
On the group? Here is the group btw.
-edit- Phil65, ill have a look at it (hadn't seen your comment before i posted)
<control type="group">
            <posx>500</posx>
            <posy>300</posy>
            <control type="button" id="1">
                <posx>180</posx>
                <posy>60</posy>
                <description>up</description>
                <height>41</height>
                <width>54</width>
                <aspectratio>keep</aspectratio>
                <texturefocus>osdcircle/point.png</texturefocus>
                <texturenofocus>osdcircle/point.png</texturenofocus>
                <onclick>Dialog.Close(VideoOSD,true)</onclick>
                <onclick>fullscreen</onclick>
                <pulseonselect>yes</pulseonselect>
                <onup>87</onup>
                <ondown>4</ondown>
                <onleft>3</onleft>
                <onright>5</onright>
            </control>
            <control type="button" id="2">
                <posx>180</posx>
                <posy>300</posy>
                <description>down</description>
                <height>41</height>
                <width>54</width>
                <texturefocus flipy="true">osdcircle/point.png</texturefocus>
                <texturenofocus flipy="true">osdcircle/point.png</texturenofocus>
                <onleft>3</onleft>
                <onup>4</onup>
            </control>
            <control type="grouplist" id="9001">
                <visible>true</visible>
                <posx>-150</posx>
                <posy>140</posy>
                <width>700</width>
                <height>300</height>
                <align>center</align>
                <orientation>horizontal</orientation>
                <itemgap>35</itemgap>
                <onup>1</onup>
                <ondown>2</ondown>
                <control type="button" id="3">
                    <posx>0</posx>
                    <posy>0</posy>
                    <height>120</height>
                    <width>150</width>
                    <texturefocus flipx="true">osdcircle/ff.png</texturefocus>
                    <texturenofocus flipx="true">osdcircle/ff.png</texturenofocus>
                    <onclick>xbmc.playercontrol(rewind)</onclick>
                    <onright>4</onright>
                </control>
                <control type="togglebutton" id="4">
                    <description>Play</description>
                    <posx>0</posx>
                    <posy>0</posy>
                    <width>150</width>
                    <texturefocus>osdcircle/play.png</texturefocus>
                    <texturenofocus>osdcircle/play.png</texturenofocus>
                    <usealttexture>Player.Playing</usealttexture>
                    <alttexturefocus>osdcircle/pause.png</alttexturefocus>
                    <alttexturenofocus>osdcircle/pause.png</alttexturenofocus>
                    <onclick>playercontrol(play)</onclick>
                    <onleft>3</onleft>
                </control>
                <control type="button" id="5">
                    <posx>0</posx>
                    <posy>0</posy>
                    <description>Rewind</description>
                    <width>150</width>
                    <texturefocus>osdcircle/ff.png</texturefocus>
                    <texturenofocus>osdcircle/ff.png</texturenofocus>
                    <onclick>xbmc.playercontrol(forward)</onclick>
                    <onleft>4</onleft>
                </control>
            </control>
            <control type="grouplist" id="9002">
                <visible>false</visible>
                <posx>-150</posx>
                <posy>140</posy>
                <width>700</width>
                <onup>1</onup>
                <ondown>2</ondown>
                    <posx>0</posx>
                    <posy>0</posy>
                    <width>150</width>
                    <texturefocus flipx="true">osdcircle/skip.png</texturefocus>
                    <texturenofocus flipx="true">osdcircle/skip.png</texturenofocus>
                </control>
                <control type="button" id="4">
                    <posx>0</posx>
                    <posy>0</posy>
                    <width>150</width>
                    <texturefocus>osdcircle/stop.png</texturefocus>
                    <texturenofocus>osdcircle/stop.png</texturenofocus>
                    <onclick>xbmc.playercontrol(stop)</onclick>
                    <onleft>3</onleft>
                </control>
                    <posx>0</posx>
                    <posy>0</posy>
                    <width>150</width>
                    <texturefocus>osdcircle/skip.png</texturefocus>
                    <texturenofocus>osdcircle/skip.png</texturenofocus>
                    <onleft>4</onleft>
                </control>
            </control>
            <control type="grouplist" id="9003">
                <visible><visible>Skin.HasSetting(ItemGroup3)</visible></visible>
                <posx>-150</posx>
                <posy>140</posy>
                <width>700</width>
                <onup>1</onup>
                <ondown>2</ondown>
                    <posx>0</posx>
                    <posy>0</posy>
                    <width>150</width>
                    <texturefocus flipx="true">osdcircle/video.png</texturefocus>
                    <texturenofocus flipx="true">osdcircle/video.png</texturenofocus>
                </control>
                    <posx>0</posx>
                    <posy>0</posy>
                    <width>150</width>
                    <texturefocus>osdcircle/getsub.png</texturefocus>
                    <texturenofocus>osdcircle/getsub.png</texturenofocus>
                    <onleft>3</onleft>
                </control>
                    <posx>0</posx>
                    <posy>0</posy>
                    <width>150</width>
                    <texturefocus>osdcircle/audio.png</texturefocus>
                    <texturenofocus>osdcircle/audio.png</texturenofocus>
                    <onleft>4</onleft>
                </control>
            </control>
        </control>
Phil65, this does seem to be what i am looking for. Except it will not go to list nr 2 (9002).
I tried a couple of different sequences. But when i get it to go to 2 and 1 it won't go to 3.
Leaves me to guess it only uses the first onclick?
(2012-09-26, 20:09)MassIV Wrote: [ -> ]Phil65, this does seem to be what i am looking for. Except it will not go to list nr 2 (9002).
uff, right, forgot that.
you have to adjust the sequence of the onclicks so that the property doesnt get toggled to 1 in line 1 and then directly to 2 in line 2 for example.
i´ll post an example in some minutes.
partly taken from xperience1080, with strings instead of properties.
<onclick condition="IsEmpty(Skin.String(CustomHomePanel2.Type))">Skin.SetString(CustomHomePanel2.Type,0)</onclick>
                            <onclick condition="stringcompare(Skin.String(CustomHomePanel2.Type),7)">Skin.SetString(CustomHomePanel2.Type,0)</onclick>
                            <onclick condition="stringcompare(Skin.String(CustomHomePanel2.Type),6)">Skin.SetString(CustomHomePanel2.Type,7)</onclick>
                            <onclick condition="stringcompare(Skin.String(CustomHomePanel2.Type),5)">Skin.SetString(CustomHomePanel2.Type,6)</onclick>
                            <onclick condition="stringcompare(Skin.String(CustomHomePanel2.Type),4)">Skin.SetString(CustomHomePanel2.Type,5)</onclick>
                            <onclick condition="stringcompare(Skin.String(CustomHomePanel2.Type),3)">Skin.SetString(CustomHomePanel2.Type,4)</onclick>
                            <onclick condition="stringcompare(Skin.String(CustomHomePanel2.Type),2)">Skin.SetString(CustomHomePanel2.Type,3)</onclick>
                            <onclick condition="stringcompare(Skin.String(CustomHomePanel2.Type),1)">Skin.SetString(CustomHomePanel2.Type,2)</onclick>
                            <onclick condition="stringcompare(Skin.String(CustomHomePanel2.Type),0)">Skin.SetString(CustomHomePanel2.Type,1)</onclick>
(2012-09-26, 20:22)phil65 Wrote: [ -> ]you have to adjust the sequence of the onclicks so that the property doesnt get toggled to 1 in line 1 and then directly to 2 in line 2 for example.
Your first example didn't do that either. Those 2 you posted two look pretty much the same to me.
This was my most recent try:
<onclick condition="IsEmpty(Window.Property(VisibleGrouplist)">SetProperty(VisibleGrouplist,9001)</onclick>
<onclick condition="Stringcompare(Window.Property(VisibleGrouplist),9003)">SetProperty(VisibleGrouplist,9001)</onclick>
<onclick condition="Stringcompare(Window.Property(VisibleGrouplist),9002)">SetProperty(VisibleGrouplist,9003)</onclick>
<onclick condition="Stringcompare(Window.Property(VisibleGrouplist),9001)">SetProperty(VisibleGrouplist,9002)</onclick>
that´s why i wrote "uff, right, forgot that." Wink
the second one definitely works, it´s tried and tested in xperience1080.
here´s the complete code snippet with both buttons directly from the skin source (includes_settings.xml). it definitely works. (you have to add the initial onempty stuff)
http://pastebin.com/mhLH4duW
Got it! Thnx so much Phil65!
Dear future self,
This is how it works:
<onload condition="IsEmpty(Window.Property(VisibleGrouplist)">SetProperty(VisibleGrouplist,9001)</onload>
<onclick condition="Stringcompare(Window.Property(VisibleGrouplist),0)">SetProperty(VisibleGrouplist,9003)</onclick>
<onclick condition="Stringcompare(Window.Property(VisibleGrouplist),9001)">SetProperty(VisibleGrouplist,0)</onclick>
