2012-09-26, 21:38
Hello everyone,
I've been trying to get my Sony BD Remote to work with XBMC and have had some success but its not working as I had hoped.
I'm very new to linux and I am using a Zotac Zbox 41 with Ubuntu 11.10 with XBMC v11.0 Eden.
I have followed the wiki on how to setup the BD remote with Ubuntu and I can get it working.
My issue is that when I get the remote paired and working within XBMC it never seems to drop the bluetooth connection and after a day or 2 I end up with 2 dead AAA batteries. I've searched around on the forums and haven't been able to find a post with the same issue as me.
Below is my Input.conf from my etc/bluetooth directory, I have edited it to match the remotes address and I have the idle time out's set so I'm not sure what I'm missing.
Is there an actual key I have to press to break the connection on the remote? My appolgies if this is something that has been brought up before and I could not find it. Thanks in advance!
# Configuration file for the input service
# This section contains options which are not specific to any
# particular interface
[General]
# Set idle timeout (in seconds) before the connection will
# be disconnect (defaults to 0 for no timeout)
#IdleTimeout=600
# This section contains options that are specific to a device
#[00:06:F7:F4:BC:5D]
# Set a custom idle timeout (in seconds) for this specific device
#IdleTimeout=30
# This section is the PS3 Remote keymap. It is loaded when bluez starts.
# Use 'uinput.h' from bluez sources or '/usr/include/linux/input.h' for
# a list of possible KEY_* values.
[PS3 Remote Map]
# When the 'OverlayBuiltin' option is TRUE (the default), the keymap uses
# the built-in keymap as a starting point. When FALSE, an empty keymap is
# the starting point.
#OverlayBuiltin = TRUE
# The mapping below is the bluez internal configuration. You'll want to
# customize it; some recommendations for XBMC are specified.
0x16 = KEY_EJECTCD # EJECT
0x64 = KEY_AUDIO # AUDIO (XBMC recommendation: KEY_A)
0x65 = KEY_ANGLE # ANGLE (XBMC recommendation: KEY_Z)
0x63 = KEY_SUBTITLE # SUBTITLE (XBMC recommendation: KEY_T)
0x0f = KEY_CLEAR # CLEAR (XBMC recommendation: KEY_DELETE)
0x28 = KEY_TIME # TIMER (XBMC recommendation: KEY_END)
0x00 = KEY_1 # NUM-1
0x01 = KEY_2 # NUM-2
0x02 = KEY_3 # NUM-3
0x03 = KEY_4 # NUM-4
0x04 = KEY_5 # NUM-5
0x05 = KEY_6 # NUM-6
0x06 = KEY_7 # NUM-7
0x07 = KEY_8 # NUM-8
0x08 = KEY_9 # NUM-9
0x09 = KEY_0 # NUM-0
0x81 = KEY_RED # RED (XBMC recommendation: KEY_F7)
0x82 = KEY_GREEN # GREEN (XBMC recommendation: KEY_F8)
0x80 = KEY_BLUE # BLUE (XBMC recommendation: KEY_F9)
0x83 = KEY_YELLOW # YELLOW (XBMC recommendation: KEY_F10)
0x70 = KEY_INFO # DISPLAY (XBMC recommendation: KEY_D)
0x1a = KEY_MENU # TOP MENU
0x40 = KEY_CONTEXT_MENU # POP UP/MENU (XBMC recommendation: KEY_F11)
0x0e = KEY_ESC # RETURN
0x5c = KEY_OPTION # TRIANGLE/OPTIONS (XBMC recommendation: KEY_C)
0x5d = KEY_BACK # CIRCLE/BACK
0x5f = KEY_SCREEN # SQUARE/VIEW (XBMC recommendation: KEY_V)
0x5e = BTN_0 # CROSS (XBMC recommendation: KEY_X)
0x54 = KEY_UP # UP
0x56 = KEY_DOWN # DOWN
0x57 = KEY_LEFT # LEFT
0x55 = KEY_RIGHT # RIGHT
0x0b = KEY_ENTER # ENTER
0x5a = BTN_TL # L1 (XBMC recommendation: KEY_F1)
0x58 = BTN_TL2 # L2 (XBMC recommendation: KEY_F2)
0x51 = BTN_THUMBL # L3 (XBMC recommendation: KEY_F3)
0x5b = BTN_TR # R1 (XBMC recommendation: KEY_F4)
0x59 = BTN_TR2 # R2 (XBMC recommendation: KEY_F5)
0x52 = BTN_THUMBR # R3 (XBMC recommendation: KEY_F6)
0x43 = KEY_HOMEPAGE # PS button
0x50 = KEY_SELECT # SELECT (XBMC recommendation: KEY_INSERT)
0x53 = BTN_START # START (XBMC recommendation: KEY_HOME)
0x33 = KEY_REWIND # SCAN BACK (XBMC recommendation: KEY_R)
0x32 = KEY_PLAY # PLAY
0x34 = KEY_FORWARD # SCAN FORWARD (XBMC recommendation: KEY_F)
0x30 = KEY_PREVIOUS # PREVIOUS (XBMC recommendationL KEY_PAGEUP)
0x38 = KEY_STOP # STOP
0x31 = KEY_NEXT # NEXT (XBMC recommendation: KEY_PAGEDOWN)
0x60 = KEY_FRAMEBACK # SLOW/STEP BACK (XBMC recommendation: KEY_COMMA)
0x39 = KEY_PAUSE # PAUSE
0x61 = KEY_FRAMEFORWARD # SLOW/STEP FORWARD (XBMC recommendation: KEY_DOT)
0xff = KEY_MAX
[General]
#IdleTimeout=600
#IdleTimeout=30
[PS3 Remote Map]
0x54 = KEY_UP # UP
0xff = KEY_MAX
