So I made the mistake of buying a B75 chipset board for my i3 with no HDMI. (DERP). Instead of buying a diff board, I figure I'll just get a dedicated card. What would be a good choice? Something fanless and comparable to hd4000 or better would be ideal.
Why not just return the board and get another one? That would probably cost less than getting a video card and the iGPU would certainly use less power than a discrete card.
(2012-09-27, 02:32)wsume99 Wrote: [ -> ]Why not just return the board and get another one? That would probably cost less than getting a video card and the iGPU would certainly use less power than a discrete card.
+1 for a new mobo with HDMI.....better airflow and less heat without a discrete GPU in it too.....I hate to see a very good HD4000 iGPU go to waste too......
(2012-09-27, 04:33)bluray Wrote: [ -> ]I hate to see a very good HD4000 iGPU go to waste too
Exactly what I was thinking too. You went the extra mile and got the i3+HD4000 and now you're not even going to use it? That just seems wrong to me.
If you want a fanless video card then your best options are probably a Nvidia GT520 or an ATI HD6450.
All good options. Let us know what you do!
