Hello Guys, Does ATV2 support VPN? If so, can you please point me to a link or thread that shows you what you need and how to set it up? THX
I don't think so, unless there is some command-line jailbreak app solution, and I wouldn't really know where to start to find that. It would probably be easiest to get a cheap router that DD-WRT can be installed on and use that as your VPN bridge for the ATV2.
Thanks Ned! Much Appreciated!
