2012-11-22, 22:04
2012-11-22, 23:52
(2012-11-22, 15:50)mikebzh44 Wrote: [ -> ]Hi Phil.
If I download Aeon Nox 3.6.1 from GITHUB : https://github.com/BigNoid/Aeon-Nox/tree/eden
Is it 3.6.1 or 3.6.2 version ?
I guess it's 3.6.2 as you have made some changes to variables.xml to use .VideoResolution instead of .Resolution properties and this properties are set by script.skin.widgets, right ?
EDIT :
I have re-install Aeon Nox 3.6.1 from XBMC repository and variables.xml already use .VideoResolution property :
Code:<variable name="ShowcaseCase-7Var">
<value condition="SubString(Container(504).ListItem(-7).Filename,.3D.)">3d.png</value>
<value>$INFO[Container(504).ListItem(-7).VideoResolution]p.png</value>
</variable>
Which script set this kind of properties ?
not a script, those are built-in.
2012-11-22, 23:55
XBMC Build-in ?
I don't understand as I haven't update my XBMC Eden since months :S
2012-11-23, 21:06
2012-11-26, 13:42
hi
Am I the only one to have ArtworkDownloader not working anymore in Nox 3.6.1 when activating it through the movie info panel?
2012-11-26, 22:51
Hi can anyone give me an idea how to install the skin, its doesn't appear to be available for download, its still broken, so how is everyone able to install?
I'm running xbmc Eden 11.0
Disregard the question I found the steps shared by fional. Link below.
http://forum.xbmc.org/showthread.php?tid...pid1150096
2012-11-28, 12:49
Hi! Is it possible to change colors and fonts of the movie, music etc lists? I managed to change colors for the homescreen and settings, but actual movie and music browsing menus seem unaltered and keep the same blue color as the default is.
2012-11-29, 16:05
Hi question from a new Aeon Nox user. I have originally used Aeon MQ3 and I'm missing the latest movies/episodes in the home menu as widget.
How do I do that on Aeon Nox?
2012-11-29, 16:32
(2012-11-29, 16:05)Bjur Wrote: [ -> ]Hi question from a new Aeon Nox user. I have originally used Aeon MQ3 and I'm missing the latest movies/episodes in the home menu as widget.
skin settings --> main menu customizer
2012-11-29, 19:03
(2012-11-29, 16:32)phil65 Wrote: [ -> ](2012-11-29, 16:05)Bjur Wrote: [ -> ]Hi question from a new Aeon Nox user. I have originally used Aeon MQ3 and I'm missing the latest movies/episodes in the home menu as widget.
Hmm i can't find the setting. Can you be clearer
2012-11-29, 19:10
(2012-11-29, 19:03)Bjur Wrote: [ -> ](2012-11-29, 16:32)phil65 Wrote: [ -> ](2012-11-29, 16:05)Bjur Wrote: [ -> ]Hi question from a new Aeon Nox user. I have originally used Aeon MQ3 and I'm missing the latest movies/episodes in the home menu as widget.
did you even try? it cannot get much easier.
2012-11-29, 19:31
Yes of course i did try but could not find the setting. I will Keep looking
2012-11-29, 19:44
(2012-11-29, 19:31)Bjur Wrote: [ -> ]Yes of course i did try but could not find the setting. I will Keep looking
System -> Skin -> Customizers -> Main menu item customizer (backgrounds,widgets)
2012-11-29, 19:45
There is only
Animated
Set path....
Show watched items in playlist widgets
Always randomize random widget items
Disable option to hide widget by presning back
Animated
Set path....
2012-11-29, 19:51
My bad, I meant:
Then you go to the Main Menu item you want (e.g. Movies), and press ENTER. not UP.
