Full Version: [WIP] Veda (discontinued)
Pages: 1 2 3
Screenshot
Minimum requirements:
Frodo only!
These should be downloaded by the skin itself:
Artwork Downloader 12.0.2 (with logo downloading enabled)
https://github.com/XBMC-Addons/script.ar.../downloads
service.skin.widgets.V0.0.13
https://github.com/XBMC-Addons/service.s.../downloads
script favorites
http://mirrors.xbmc.org/addons/frodo/script.favourites/
Hey everyone Big Grin
This project started as a Fusion Mod (Credits).
Mostly i wanted to learn the ins and outs of skinning.
Latest 'stable' version: 0.1.2
Updated (19-06-2013)
Install repository: https://code.google.com/p/skin-git/downloads/list
Then go to addons and install skin.
big like
clean look
I'm going to reserve judgment until the images have proper aspect ratios, cause that is driving me nuts Wink
The images... Could you possibly be more vague?
Edited:
Now aspect ratio looks fine, nice concept btw
(2012-09-27, 19:41)MassIV Wrote: [ -> ]The images... Could you possibly be more vague?
The movie poster images.
Np, it's what feedback is for. I really only have a small 1280x800 screen to test on atm.
And even with aspect ratios intact things don't always seem to scale the same way.
So what screen dimension are you using? 16x9 - 16x10 - 4x3? Or a resolution, also fine.
And are we talking in the videoOSD or in the library?
1920x1080 (16:9)
Library and OSD.
Yeah that might be a bit much. Consider it to be on the to-do list. Though the solution i want will take time.
And i'm not starting on viewtypes until the posters vs banners thing gets sorted.
-edit- Quick fixed.
Hi There,
I'm trying to install but it displays the message "depencies not met"
Make sure you are running an up to date Nightly.
And/or manually unpacking and placing it in your skin folder.
Remember this skin is not finished.
I like it! Keep up to good work! Smile
Foir your aspect ratios... maybe you could add a switch in the skin's option so that people can go from 16:9 to 4:3? Just an idea.
No need for an option when this can be coded in the skin.
(2012-10-01, 16:48)Hitcher Wrote: [ -> ]No need for an option when this can be coded in the skin.
Please do elaborate...
-edit- thnx
Would it be possible to add end time to player osd?
What about adding recently added when highlighting tv shows something like this
Pages: 1 2 3
