I'm using Confluence (the default skin).
15:48:20 T:2028 NOTICE: -----------------------------------------------------------------------
15:48:20 T:2028 NOTICE: Starting XBMC (12.0-ALPHA6 Git:20121001-f4d8117), Platform: Windows 7, 64-bit (WoW) Service Pack 1 build 7601. Built on Oct 1 2012 (compiler 1600)
15:48:20 T:2028 NOTICE: AMD Phenom(tm) II X4 955 Processor
15:48:20 T:2028 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
15:48:20 T:2028 NOTICE: Running with restricted rights
15:48:20 T:2028 NOTICE: Aero is enabled
15:48:20 T:2028 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
15:48:20 T:2028 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
15:48:20 T:2028 NOTICE: special://masterprofile/ is mapped to: C:\Users\Jeff\AppData\Roaming\XBMC\userdata
15:48:20 T:2028 NOTICE: special://home/ is mapped to: C:\Users\Jeff\AppData\Roaming\XBMC\
15:48:20 T:2028 NOTICE: special://temp/ is mapped to: C:\Users\Jeff\AppData\Roaming\XBMC\cache
15:48:20 T:2028 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
15:48:20 T:2028 NOTICE: Local hostname: JEFF
15:48:20 T:2028 NOTICE: Log File is located: C:\Users\Jeff\AppData\Roaming\XBMC\xbmc.log
15:48:20 T:2028 NOTICE: Enumerated WASAPI devices:
15:48:20 T:2028 NOTICE: Device 1
15:48:20 T:2028 NOTICE: m_deviceName : {16825ECE-4133-4409-9A05-85B85E187814}
15:48:20 T:2028 NOTICE: m_displayName : Speakers - Speakers (High Definition Audio Device)
15:48:20 T:2028 NOTICE: m_displayNameExtra: WASAPI: Speakers (High Definition Audio Device)
15:48:20 T:2028 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:48:20 T:2028 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
15:48:20 T:2028 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100
15:48:20 T:2028 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
15:48:20 T:2028 NOTICE: Device 2
15:48:20 T:2028 NOTICE: m_deviceName : {187265AF-78D7-4BD9-96C6-88CCCAE5E69C}
15:48:20 T:2028 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (High Definition Audio Device)
15:48:20 T:2028 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (High Definition Audio Device)
15:48:20 T:2028 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
15:48:20 T:2028 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
15:48:20 T:2028 NOTICE: Device 3
15:48:20 T:2028 NOTICE: m_deviceName : {4ED3390F-C9DB-4BAB-945F-D136BF85EF28}
15:48:20 T:2028 NOTICE: Enumerated DirectSound devices:
15:48:20 T:2028 NOTICE: m_displayNameExtra: DirectSound: Speakers (High Definition Audio Device)
15:48:20 T:2028 NOTICE: m_sampleRates : 48000
15:48:20 T:2028 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
15:48:20 T:2028 NOTICE: m_displayNameExtra: DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device)
15:48:20 T:2028 NOTICE: m_sampleRates : 44100
15:48:20 T:2028 NOTICE: load settings...
15:48:20 T:2028 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:48:20 T:2028 NOTICE: loading special://masterprofile/guisettings.xml
15:48:20 T:2028 NOTICE: Getting hardware information now...
15:48:20 T:2028 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:48:20 T:2028 NOTICE: Loaded playercorefactory configuration
15:48:20 T:2028 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:48:20 T:2028 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:48:20 T:2028 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:48:20 T:2028 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
15:48:20 T:2028 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videolibrary>
<cleanonupdate>true</cleanonupdate>
</videolibrary>
</advancedsettings>
15:48:20 T:2028 NOTICE: Default DVD Player: dvdplayer
15:48:20 T:2028 NOTICE: Default Video Player: dvdplayer
15:48:20 T:2028 NOTICE: Default Audio Player: paplayer
15:48:20 T:2028 NOTICE: Disabled debug logging due to GUI setting. Level -1.
NOTE: I have experienced this in Dharma, Eden, and Frodo (which this log is from).
