Full Version: Brand New Setup - Need Config help
I just did a brand new installation following Gort's A6 build here:
http://forum.xbmc.org/showthread.php?tid=138734
I would like to know if there are any posts someone can direct me to that give all of the simple configuration steps such as installing needed codecs, etc, on a brand new build.
This machine is only to be used as a Media Player in the living room so nothing else is needed.
It has Windows 7 installed.
No codecs are required for XBMC (built in), you should be good to go... but do peruse the add-ons in the official repository for some extras, and I'd be amiss to not recommend some extra scrapers.
Awesome. Thanks PatK for the advice!
(2012-09-29, 00:23)kobekatt Wrote: [ -> ]This machine is only to be used as a Media Player in the living room so nothing else is needed.
What are you trying to achieve (1080P video, bitstreaming HD audio, etc) with your HTPC?
