2012-09-30, 04:56
I have my PC hooked up to my projector, which supports the full 0-255 range, and my PC is set to 16-235 in the Nvidia control panel. I have the projector calibrated to display about 15-245ish, as recommended by the good folks at AVS forums. Here's my question... How does Nvidia handle the full 0-255 setting? If I'm primarily using my PC to play MKV files through XBMC, should I keep the color range set to 16-235 or should I change it to 0-255? Would my MKV files benefit from that setting, or would it "extend" those colors resulting in crushed blacks displayed by my projector? Theres also something called Dynamic Contrast Enhancement and Color Enhancement. Would XBMC benefit from either of those?
Or, to make things super easy, should I just leave this to "use video player settings" in the control panel and not worry about all of those settings?
