Full Version: The Trailers and couchpotato v2. Not working?
I am running The Trailers and on the same machine an installation of CPv2. CP is set up in The Trailers' settings, but everytime I want to add a movie it says "CP couldnt find the movie you are looking for" (I am not at home at the moment, sorry for the approximation). At first I thought I was missing something like the IMDB Plugin, but that one is installed.
Does anyone know what might be missing or can point me in the right direction?
Thank you very much!
Kind regards, Kiesel
CP v2 support was added in a recent version, did you check your options and set it to v2? If it's not in the options try and update it manually from here https://github.com/XBMC-Addons/plugin.vi.../downloads , worked for me.
