Full Version: Crash with .ass subtitle
I'm pretty sure the crash is caused by the .ass subtitle
Running nightly of 29 of Sep
Movie runs for 10 min and crashes
xbmclog
http://xbmclogs.com/show.php?id=9600&hash=13490243
Crashreporter, low mem log
http://xbmclogs.com/show.php?id=9602&hash=24496134
There are no other crashreporter logs available.
Could you cut a small sample with the scene which is giving you lowmem crash? Verify that its still crashing with the cut example and dropbox it or so...
mmm, never done that before. Any open source soft that I can use for this mp4?
In addition, the crash doesn't always occur at the very same spot, a difference of a couple of minutes is quite normal
p.s I solved the problem for myself by simply converting the .ass to .srt but that doesn't solve the problem in general.
Upload that .ass file. That should be enough (i could just lay it under another movie i guess).
