(2013-02-18, 08:44)olympia Wrote: [ -> ]You set it to be hidden, because it is displayed by default. You should find the place again... You know, most of the times it make sense to read the options you set/enable, not just blindly enable everything as the more was better.
It's in settings, you will find it.
Thanks for your reply but maybe you should ask me first if I had indeed disabled it - which I hadn't, before you go off on a rant!
Looks like it can't find HD-Trailers anymore
(I refreshed the same movie, on the same scraper's settings. Before that I had the trailer, after that I no longer have it).
Then I have to say that HD-Trailers were slooooow at buffering... maybe they just brought all of them down... ?
Hi
Is this the proper place for feature requests concerning "TheMovieDB" add-on? I'm really excited about the results of this add-on but definitively missing one feature:
Especially in combination with the option "keep original title" it would be awesome to have another option leading the scraper to also download the poster in the original language of the movie
(or a custom language if anyone would want this)! Of course it should fall back on posters in "preferred language" if no posters in the original language exist.
This shouldn't be too difficult to implement I guess since the posters on themoviedb.org already have a language attribute...
In the current version of this add-on movies always get different titles and "poster titles" if the option "keep original title" is activated and the orignal title isn't in the "preferred language". This is pretty annoying in my view and at least inconsistent from a technical view.
I hope others feel the same
PS: I'm using XBMC 12.1 and TheMovieDB 3.7.2
there seems to be an utf8 encoding problem:
18:47:00 T:4638216192 DEBUG: FindMovie: Searching for 'Dänische Delikatessen' using The Movie Database scraper (path: '/Applications/XBMC.app/Contents/Resources/XBMC/addons/metadata.themoviedb.org', content: 'movies', version: '3.7.2')
18:47:00 T:4638216192 DEBUG: scraper: CreateSearchUrl returned <url>http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=d?%a4nische%20delikatessen&year=2003&language=de</url>
18:47:00 T:4638216192 DEBUG: CurlFile::Open(0x117d09af0) http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=dÃ%a4nische%20delikatessen&year=2003&language=de
the ä is encoded in ?%a4 -> this looks like double utf8 encoding
the right encodings are here:
http://www.fileformat.info/info/unicode/.../index.htm
html entity in hex works:
http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=dänische%20delikatessen&year=2003&language=de
html entity in decimal works:
http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=d & # 2 2 8 ;nische%20delikatessen&year=2003&language=de
whitespaces must be removed!
but utf8 encoded ä doesn't work:
http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=d%C3%A4nische%20delikatessen&year=2003&language=de
could you please look at this?
why is slovak language missing in this addon? please fix it, thanks
I am having the same problem with german special characters as bulinski (2 posts above me):
15:01:25 T:7788 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'X:\Video\Movies\Bolt - Ein Hund für alle Fälle (2008).avi'
15:01:25 T:7788 DEBUG: ADDON::CScraper::FindMovie: Searching for 'Bolt - Ein Hund für alle Fälle' using The Movie Database scraper (path: 'D:\Programme\Media\XBMC\addons\metadata.themoviedb.org', content: 'movies', version: '3.7.2')
15:01:25 T:7788 DEBUG: scraper: CreateSearchUrl returned <url>http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=bolt%20-%20ein%20hund%20f%c3%bcr%20alle%20f%c3%a4lle&year=2008&language=de</url>
15:01:25 T:7788 DEBUG: CurlFile::Open(0A6A5B58) http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=bolt%20-%20ein%20hund%20f%c3%bcr%20alle%20f%c3%a4lle&year=2008&language=de
15:01:25 T:7788 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://api.themoviedb.org
15:01:25 T:7788 DEBUG: scraper: GetSearchResults returned <results></results>
15:01:25 T:7788 DEBUG: ADDON::CScraper::FindMovie: Searching for 'Bolt Ein Hund für alle Fälle' using The Movie Database scraper (path: 'D:\Programme\Media\XBMC\addons\metadata.themoviedb.org', content: 'movies', version: '3.7.2')
15:01:25 T:7788 DEBUG: scraper: CreateSearchUrl returned <url>http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=bolt%20%20%20ein%20hund%20f%c3%bcr%20alle%20f%c3%a4lle&year=2008&language=de</url>
15:01:25 T:7788 DEBUG: CurlFile::Open(0A6A5B58) http://api.themoviedb.org/3/search/movie?api_key=57983e31fb435df4df77afb854740ea9&query=bolt%20%20%20ein%20hund%20f%c3%bcr%20alle%20f%c3%a4lle&year=2008&language=de
15:01:25 T:7788 WARNING: No information found for item 'X:\Video\Movies\Bolt - Ein Hund für alle Fälle (2008).avi', it won't be added to the library.
Please help! Thank you!
Thanks for the info. I have hope
Is it possible to translated the word "Rated" in the German translation into "FSK"?
So that the result is something like:
Altersfreigabe: FSK 16 instead of Altersfreigabe: Rated 16 or remove "Rated" completly"
That would make more sense under the German surface.
Thanks in advance.
(2013-05-07, 16:14)MeC!as Wrote: [ -> ]Is it possible to translated the word "Rated" in the German translation into "FSK"?
Thanks in advance.
Use the Universal Scraper and configure this as you wish.
Thanks for the advise. Didn't know the universal scraper. Works fine for me.
Yay, thanks for noticing. Thats good news!
Is it on my side or is scraping from TMDB extremely slow at the moment? Takes me like several hours to scrape ~300 movies.
