Full Version: VNSI errors
I am not sure if i am right with a VNSI question within this forum, but maybe someone is able to help me.
Setup is
VDR + VNSI + DVBAPI on my server and openelec with XBMC PVR on my client.
but for some reason it does not work
Oct  1 20:32:10 nagafen vdr: [25047] setstatus 0
Oct  1 20:32:10 nagafen vdr: [25054] setstatus 0
Oct  1 20:32:10 nagafen vdr: [25054] setstatus 1
Oct  1 20:32:10 nagafen vdr: [25054] Filter Pid:0,Tid:0 added.
Oct  1 20:32:10 nagafen vdr: [25060] VNSI: Requesting clients to reload channel list
Oct  1 20:32:13  vdr: last message repeated 6 times
Oct  1 20:32:13 nagafen vdr: [25054] PMT scan idle
Oct  1 20:32:13 nagafen vdr: [25054] EEPG: Ended all processing
Oct  1 20:32:31 nagafen vdr: [25047] setstatus 0
Oct  1 20:32:31 nagafen vdr: [25054] setstatus 0
Oct  1 20:32:31 nagafen vdr: [25054] setstatus 1
Oct  1 20:32:31 nagafen vdr: [25054] Filter Pid:0,Tid:0 added.
Oct  1 20:32:32 nagafen vdr: [25060] VNSI: Requesting clients to reload channel list
Oct  1 20:32:37  vdr: last message repeated 10 times
Oct  1 20:32:37 nagafen vdr: [25054] PMT scan idle
Oct  1 20:32:37 nagafen vdr: [25054] EEPG: Ended all processing
Oct  1 20:32:48 nagafen vdr: [25147] cLiveStreamer stream processor thread ended (pid=25047, tid=25147)
Oct  1 20:32:48 nagafen vdr: [25071] buffer stats: 223720 (7%) used
Oct  1 20:32:48 nagafen vdr: [25071] CAM 2: assigned to device 1
Oct  1 20:32:48 nagafen vdr: [25071] setstatus 0
Oct  1 20:32:48 nagafen vdr: [25071] VNSI: Creating new live Receiver
Oct  1 20:32:48 nagafen vdr: [25429] cLiveStreamer stream processor thread started (pid=25047, tid=25429)
Oct  1 20:32:48 nagafen vdr: [25149] TS buffer on device 1 thread ended (pid=25047, tid=25149)
Oct  1 20:32:48 nagafen vdr: [25148] buffer stats: 112424 (2%) used
Oct  1 20:32:48 nagafen vdr: [25148] receiver on device 1 thread ended (pid=25047, tid=25148)
Oct  1 20:32:48 nagafen vdr: [25071] DVBAPI: 0.0 set CAM decrypt (SID 13012, caLm 4, HasCaDescriptors 1)
Oct  1 20:32:48 nagafen vdr: [25071] VNSI: Successfully switched to channel 5 - ATV
Oct  1 20:32:48 nagafen vdr: [25430] receiver on device 1 thread started (pid=25047, tid=25430)
Oct  1 20:32:48 nagafen vdr: [25071] VNSI: Started streaming of channel ATV (timeout 10 seconds)
Oct  1 20:32:49 nagafen vdr: [25431] TS buffer on device 1 thread started (pid=25047, tid=25431)
Oct  1 20:32:49 nagafen vdr: [25052] setstatus 0 Oct  1 20:32:49 nagafen vdr: [25052] setstatus 1
Oct  1 20:32:49 nagafen vdr: [25052] Filter Pid:0,Tid:0 added.
Oct   1 20:32:49 nagafen vdr: [25060] VNSI: Requesting clients to reload channel list
Oct  1 20:32:52  vdr: last message repeated 5 times
Oct  1 20:32:52 nagafen vdr: [25047] setstatus 0
Oct  1 20:32:52 nagafen vdr: [25054] setstatus 0
Oct  1 20:32:52 nagafen vdr: [25054] setstatus 1
Oct  1 20:32:52 nagafen vdr: [25054] Filter Pid:0,Tid:0 added.
Oct  1 20:32:52 nagafen vdr: [25060] VNSI: Requesting clients to reload channel list
Oct  1 20:32:57  vdr: last message repeated 11 times
Oct  1 20:32:57 nagafen vdr: [25052] PMT scan idle
Oct  1 20:32:57 nagafen vdr: [25052] EEPG: Ended all processing
Oct  1 20:32:57 nagafen vdr: [25054] PMT scan idle
Oct  1 20:32:57 nagafen vdr: [25054] EEPG: Ended all processing
Oct  1 20:32:58 nagafen vdr: [25429] VNSI: returning from streamer thread, timeout on starting streaming
Oct  1 20:32:58 nagafen vdr: [25429] cLiveStreamer stream processor thread ended (pid=25047, tid=25429)
Oct  1 20:33:04 nagafen vdr: [25430] buffer usage: 70% (tid=25429)
Oct  1 20:33:04 nagafen vdr: [25430] buffer usage: 80% (tid=25429)
Oct  1 20:33:05 nagafen vdr: [25430] buffer usage: 90% (tid=25429)
Oct  1 20:33:06 nagafen vdr: [25430] buffer usage: 100% (tid=25429)
Oct  1 20:33:06 nagafen vdr: [25430] ERROR: 1 ring buffer overflow (77 bytes dropped)
Oct  1 20:33:12 nagafen vdr: [25430] ERROR: 17326 ring buffer overflows (3257288 bytes dropped)
Oct  1 20:33:13 nagafen vdr: [25047] setstatus 0
Oct  1 20:33:13 nagafen vdr: [25054] setstatus 0
Oct  1 20:33:13 nagafen vdr: [25054] setstatus 1
Oct  1 20:33:13 nagafen vdr: [25054] Filter Pid:0,Tid:0 added.
Oct  1 20:33:13 nagafen vdr: [25060] VNSI: Requesting clients to reload channel list
Oct  1 20:33:18  vdr: last message repeated 6 times
Oct  1 20:33:18 nagafen vdr: [25430] ERROR: 18206 ring buffer overflows (3422728 bytes dropped)
do i simple need more buffer? if yes, where can i adjust the size?
tia
You don't even let us know what versions you are using. It's impossible then to give any help.
Note that any questions related to Softcams are not allowed in this forum. Does it work without DVBAPI?
