Hi all i have created 6 Custom home screen menu using playlist, working a treat
So here is my question
when i was setting background image (if i select live dvd case it gives you the option to set content so i selected movie playlist) but nothing seems to happen
does this feature work
Cheers for Looking
hi phil65
i have selected this but nothing happens all i get is empty dvd cases
hope you can help
Sami
You may be missing a script. Look through your xbmc.log around the time when you set that option, and you may see an error relating to "script.playlist".
you have to enable a widget also to choose latest or random vpl. you can disable the widget onxe the covers are visible. We'll see how we can improve that.
(2012-10-02, 23:27)Big_Noid Wrote: [ -> ]you have to enable a widget also to choose latest or random vpl. you can disable the widget onxe the covers are visible. We'll see how we can improve that.
will be improved when the smart playlist stuff is done. everything will work on its own then.
Thanks Big_Noid,thrak76,Phil65
I enabled widget then VPL worked fine on background selection
Cheers every one
Just one more thing if u can help what size folder.jpg do i need for them to show up in dvd case
Cheers again
