Full Version: Disable vertical scrollbars
Hi - thank you so much for the skin. It's makes XBMC look incredible on my Mac Mini. By ATV2 struggles somewhat but that's another matter...
I have done a scour on the web looking for this feature or perhaps an XML setting but to no avail:
Is there anyway to disable vertical scrollbars? (independently from horizontal).
My harmony remote uses the Channel + and - buttons for scrolling, so I don't need a separately selectable scrollbar control. In fact for the uninitiated selecting the scroll bar inadvertently can be quite confusing (it's not always obvious when the scrollbar is selected - perhaps shading the background behind the scrollbar may fix that).
Scott
