Any ETA on 1.2.0? Or are you implementing some new icons for it?
1.2.0 is basically ready. I'm waiting on 2 transaltions, but I'll wait another couple of days, then I'll upload.
No new icons for now sorry. The ones You sent are awesome, but there's only 3 or 4, so they would take away consisntency. I'd need an open layered one in order to change them all... plus they have different A/R..
I disabled the default icons on the skin and added "favorites" to movies, music, etc and then pointed the icons at the ones I sent you. I think they look great, I wish I had the rest though. You say you have an Apple TV? Can't you rip them?
This is what I got so far:
Feature Request: Localized Certificates. Lots of skins overlook this feature, its must-have imo.
Any one are or used in the raspberry pi? any tips to optimizer the skin?
Does it have support for Cinema Experience?
would be a nice addition imho
http://code.google.com/p/xbmc-addons/wik...kinSupport
(2013-01-21, 03:44)jamesdm Wrote: [ -> ]Any one are or used in the raspberry pi? any tips to optimizer the skin?
im using it, my recommendation is turn off most options and then apply the ones you need basically less is always more also take a peak in the raspberry subforum here for more tips loads of addons that aren't nessesary that might be running along with other good tips and tricks but so far this is the best skin due to the clean layout to be running on RPi
(2013-01-19, 17:20)oriongb Wrote: [ -> ]Feature Request: Localized Certificates. Lots of skins overlook this feature, its must-have imo.
I don't even know what they are.....
You mean localized movie certification?
I know lots of people is using SiO2 on Pi... also on the xbmchub forum you might find useful infos...
(2013-01-21, 11:04)swetoast Wrote: [ -> ]Does it have support for Cinema Experience?
The skin already supports Cinema Experience!!
I am not shure Cinema Experience Addon is ready for Frodo though...
..last I checked wasn't working.
ahh k good news there you really should setup a git for your skin and document makes it easier then following everything in this thread thus not getting the same requests over and over again
Cool ill take a wack at it someday when i got more time and read thru this thread and add missing info
(2013-01-21, 13:54)fastcolors Wrote: [ -> ] (2013-01-19, 17:20)oriongb Wrote: [ -> ]Feature Request: Localized Certificates. Lots of skins overlook this feature, its must-have imo.
Yea sorry, like movie ages. Restrictions, Certificates, whatever.
I can find a tutorial on how to do it if you are not sure
