Full Version: I have problems with xbmc remote and samsung galaxy s3
Hello!
When i am trying connect to xbmc with xbmc remote. what is the problem?
Possibly your configuration ?...
i have the xbmc remote functioning fine on my Galaxy S3... so i don't think its the phone.
how do u have configuration your mobile and xmbc program?
Perhaps this may help you with configuration.
If you are running Frodo, you need the new app that is not in the play store yet because it needs the new JSON API option. Just look up the xbmc remote forum (sorry, on my phone right now and can't get you a link) just make sure once installed, check the JSON API box
