2012-10-05, 21:04
I'm running an XBMC session on UBUNTU 12.04.
I'm running it on a DELL D630, with a DVI to HDMI converter on the docking station. The machine outputs to the TV just fine.
Wnen the machine boots, i have it log right in with an XBMC session, automatically. It looks fantastic.
At some point, the screen goes black. Not sure when this happens. (Might be after I've switched TV inputs, and switched back.) But I get a black screen eventually.
I can't seem to get out of this black screen - no amount of banging on the keyboard can throw me back to my XBMC session. I'm using the android remote, and I can hear menu navigation sounds on my speakers. So I know that XBMC is still running. And I know that the TV is getting the black screen from the Dell, since its not reporting its normal "No Signal" message on a blue screen.
The logs don't hint at anything - either XBMC logs, or local system logs.
So thats the problem.
What can I check?
- Thanks,
Todd
What can I check?
- Thanks,
Todd
