I have notice an audio problem. my setup is 2.1 but only getting audio out of right speaker and bass. no audio out of left speaker in XBMC alpha 6 64 bit.
Same on the 32bit Version i guess?
xbmc.log (wiki) needed.
does anyone know the path were the logs are saved in Frodo?
Wiki:
Future Frodo feature: special://logpath - This path points to the path where the Log_file is saved. available in nightlies/Pre-Frodo since Aug 5th.
under my userdata folder there only 2 xml files and in the Logs folder no xbmc log at all. what I do have is an older folder call DiagnosticReport
xbmc.log (wiki) - could you please answer my question?
Make sure you are looking in your username Library directory and not the system-wide Library directory.
I have install yesterdays nightly and problem continues any update on this?
You refused to answer my simple question i have asked 2 times now. Find someone else ...
and your advancedsettings.xml is broken:
20:28:58 T:140735190026592 ERROR: Error loading special://profile/advancedsettings.xml, Line 17
Error reading end tag.
