I have a small problem using PVR on my Raspberry Pi. Every time I change channel, my screen gets re-adjusted (blank for a second or two). This is quite annoying. I have my Pi connected with HDMI. Is there a way to disable that or is this a bug?
Thank you in advance!
You could turn off "adjust display refresh rate to match video".
This doesn't seem to affect PVR playback - normal playback works fine. I'll try with the newest OpenELEC build and report back.
Latest OpenELEC status: My screen still readjusts when I start watching TV (on any setting). Also most of the channels don't work anymore (I just get the first frame or not even that).
hallo
it looks like we have the same issue, I run with a external TVHeadend server and the screen just becomes muddy and freezes.
As you can see here it run more stable on a R11974
External TVheadend problem
Which version of open elec are you running, I am not able to turn pvr on at all, but which adding are u using.
TVHeadend. As tjay78 noted, it stopped working a few builds ago.
I opened this thread for other reasons - due to annoying display adjustment on PVR.
