Full Version: Resolution problems
I have multiple devices hooked up to my tv, and when I switch devices, XBMC retains the resolution of the last device i had hooked up. For instance, If I am watching xbmc, switch to my xbox, and then switch back to xbmc, the program will be displayed in 720p resolution instead of 1080p. The only way to fix this is to exit the program and restart it.
I am running Eden on Windows 7. The problem has persisted on multiple GPUs.
