Full Version: Remuxed Videos Play out of sync
Before I got a RaspberryPi and started using XBMC, I used to stream my media files to my PS3 via PS3 Media Server and with that I would have to remux any MKV's into a different container using MKV2VOB [Which I used mpg for this]. Now Up until XBian 0.8.1b and RaspBMC RC5 had been released, these files were working fine but since the updates, any of these remuxed files play out of sync.
Here is some media info:
File 1
General
Complete name                            : Episode.mpg
Format                                   : MPEG-TS
File size                                : 1.52 GiB
Duration                                 : 43mn 29s
Overall bit rate mode                    : Variable
Overall bit rate                         : 4 987 Kbps
Maximum Overall bit rate                 : 35.5 Mbps
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : [email protected]
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 5 frames
Codec ID                                 : 27
Duration                                 : 43mn 29s
Bit rate mode                            : Variable
Bit rate                                 : 4 597 Kbps
Maximum bit rate                         : 40.0 Mbps
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.200
Stream size                              : 1.38 GiB (91%)
Writing library                          : x264 core 107 r1772 c9dad9e
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4597 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.0
Audio
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : 129
Duration                                 : 43mn 29s
Bit rate mode                            : Constant
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 59.7 MiB (4%)
File 2:
General
Complete name                            : episode.mpg
Format                                   : MPEG-TS
File size                                : 497 MiB
Duration                                 : 29mn 43s
Overall bit rate                         : 2 337 Kbps
Video
Menu ID                                  : 1 (0x1)
Format                                   : AVC
Format settings, ReFrames                : 16 frames
Codec ID                                 : 27
Duration                                 : 29mn 43s
Bit rate                                 : 2 000 Kbps
Width                                    : 700 pixels
Height                                   : 568 pixels
Display aspect ratio                     : 5:4
Color space                              : YUV
Bit depth                                : 8 bits
Bits/(Pixel*Frame)                       : 0.201
Stream size                              : 431 MiB (87%)
Writing library                          : x264 core 60 r899M f8428ed
Encoding settings                        : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=7 / rdcmp=psy / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=0 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=2000 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.0
Audio
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Codec ID                                 : 129
Duration                                 : 29mn 43s
Bit rate                                 : 192 Kbps
Bit depth                                : 16 bits
Stream size                              : 40.8 MiB (8%)
Hope this helps
