Found several posts asking how to lighten the fanart in this skin, but no one seems to respond to the posts. So does anyone know which xml file needs to be altered?
What I did was edit the ContentPanel.png file with an image editor to make it more transparent. It is located in the C:\Users\[UserName]\AppData\Roaming\XBMC\addons\skin.neon\media folder.
Although I think I may have had to extract it from a textures file. And there may be a way to modify transparency in an xml file. I'm not sure.
Here's a link to the modified, more transparent png file. Save it in your C:\Users\
UserName\AppData\Roaming\XBMC\addons\skin.neon\media folder.
