First of all thanks for this great addon
One question: Is it possible to get 'Most Played Artist' displayed? :/
The post i removed a little higher up was also about the unicode or str error.
It resolved itself after my addons updated themselves, i believe after a library update.
Everything working fine now on Beta2.
Can someone help me by pointing me to where the deufault.py file is that i need to edit? I'm running ubuntu 12.04 lts with xbmc beta 3. i still have the script failed error for services.skin.widgets
(2012-12-10, 00:09)Vinnie85 Wrote: [ -> ]Can some help me by pointing me to where the deufault.py file is that i need to edit? I'm running ubuntu 12.04 lts with xbmc beta 3. i still have the script failed error for services.skin.widgets
Should be in your $HOME/.xbmc/userdata/addons/service.skin.widgets folder.
Top! It work realy good for me
I have installed Frodo RC1 but canĀ“t install this script cause of net met dependencies?
Can someone point me into the right direction?
Marked as broken in the repo, according to a message that popped up in xbmc.
(2012-12-13, 00:26)Death-Axe Wrote: [ -> ]Marked as broken in the repo, according to a message that popped up in xbmc.
Changelog: v0.0.17
- Try to break all skins
- Updated language files from Transifex
im guessing why its not updating is because in the addon.xml, requirements were added:
<requires>
<import addon="xbmc.addon" version="12.0.0"/>
<import addon="xbmc.json" version="6.0.0"/>
<import addon="xbmc.python" version="2.1.0"/>
<import addon="script.module.simplejson" version="2.0.10"/>
</requires>
This
is what i think is the problem...it should be 12.0 not 12.0.0
Martijn
why try to break all skins?
So as of this morning skin.widgets reports as broken in the repository for me (as stated above). I can't get it to update or function at all.
Is it possible to change the TV Show recently episode preview pictures to season folder pictures ? or make it an option ?
i tried to read the py but i can't find the place where it tries to load the pictures..
(2012-12-15, 02:41)joeblack2k Wrote: [ -> ]Is it possible to change the TV Show recently episode preview pictures to season folder pictures ? or make it an option ?
no season images (and won't add it)
Where does Skin widgets get series posters from? the posters its displaying for my shows aren't the ones that I've got set in my library?
