@Martijn: Trailer property is missing in recommend/random movies.
Added recent items:
movies
episodes
albums
Updated the wiki page
Note:
For recent items to work correctly you need a nightly of October 20, 2012 or later
Are watched items included?
(2012-10-19, 23:05)Hitcher Wrote: [ -> ]Are watched items included?
optional through settings
This goody is getting better and better every day
Thanks Martijn
Hi Martijn.
Is it possible to add Resolution property for Movies ?
I need this property to mod the DVD live background Aeon Nox wall paper.
I have added it to your script, you can have a look :
http://xbmclogs.com/show.php?id=11171
DVD Live Background for smart playlist because (as my script return resolution properties
(2012-10-22, 13:18)mikebzh44 Wrote: [ -> ]Hi Martijn.
DVD Live Background for smart playlist because (as my script return resolution properties ) :
I don't like the try except because it isn't needed and you have no good way of knowing what it really should be.
I have a better way of getting resolution:
https://github.com/XBMC-Addons/script.ar...up.py#L151
Will see how much time it costs extra to process this but i doubt it would be much so i'll probably add this.
Thanks for the tip and I hope that extra informations won't cost a lot.
I can adjust in such a way it will directly give the correct filename on what case to use so there will be no need for stringcompares in the skin.
So how are the cases named in general?
For Aeon Nox :
0.0.7
- Added resolution tag for movies based on filename or streamdetails (3d, 1080, 720, 576, 480)
relevant code
Window property name: "Resolution"
- Prefer new database 'Art' field over old 'thumb' and use local files as backup
