Full Version: Advice on Build
Hello ive been lurking around using the info from the site in order to get ideas for a first build and would appreciate any feedback on this proposed setup.
Silverstone ML03B Case
Be Quiet SFX 300W MicroATX PSU
Gigabyte F2A75M-D3H
AMD A6-5400K
Crucial 8GB DDR3 1866Mhz Ballistix Tactical Memory
OCZ 60GB Agility 3 SSD
Many Thanks, Ben
You'll also need an SFX-to-ATX bracket (sometimes also called SFX-to-PS2) for securing the power supply to the case.
I prefer the Crucial M4 64GB SSD over the OCZ based on the hit-or-miss nature of the reviews and posts I've seen in forums.
Everything else looks great.
If you'd rather not deal with installing a bracket for that PSU,...I'd suggest and use the SilverStone Strider 400W, 80 PLUS, Active PFC Power Supply ST40F-ES (Black) in that same case.
+1 for the SST-ST40F-ES. I have one in my ML03B and it fit great, and is VERY quiet
(2012-10-10, 14:31)GortWillSaveUs Wrote: [ -> ]If you'd rather not deal with installing a bracket for that PSU...
It's not a big deal to install the bracket -- it's four extra screws Smile.
(2012-10-10, 14:25)Dougie Fresh Wrote: [ -> ]You'll also need an SFX-to-ATX bracket (sometimes also called SFX-to-PS2) for securing the power supply to the case.
(2012-10-10, 14:31)GortWillSaveUs Wrote: [ -> ]If you'd rather not deal with installing a bracket for that PSU,...I'd suggest and use the SilverStone Strider 400W, 80 PLUS, Active PFC Power Supply ST40F-ES (Black) in that same case.
(2012-10-10, 15:29)Arkitket Wrote: [ -> ]+1 for the SST-ST40F-ES. I have one in my ML03B and it fit great, and is VERY quiet
+1 on all said.... as you can see on amazon most frequently bought are the ml03b and the strider...
Wow, great advice. Thanks to everyone! excited to get started!
