I'm running Eden on Wind 7 64bit. Sometimes the cursor will start continuously scrolling down and will not stop forcing me to kill it from task manager. It will happen while using either the android remote and or standard remote.
Any ideas on the cause? or if you need more info?
(2012-10-10, 20:43)weibergj Wrote: [ -> ]I'm running Eden on Wind 7 64bit. Sometimes the cursor will start continuously scrolling down and will not stop forcing me to kill it from task manager. It will happen while using either the android remote and or standard remote.
I've have had this same but not sure how i solved it.
Are you still on Eden or move to Frodo?
(2012-10-10, 21:29)weibergj Wrote: [ -> ]Are you still on Eden or move to Frodo?
Moved over to Frodo about half a year ago.
iirc there where some other reports about this.
not sure if it would do any good but you can try changing this setting:
settings -> system -> input devices -> remote control sends keyboard presses.
Try playing with those settings. Maybe some one else has another idea.
