2012-10-10, 22:33
I am running XBMCbuntu 11.0 on an Intel Atom D525 and cannot get crossfade to work.
My audio settings:
Audio output: Optical/Coax
Speaker Configuration: 2.0
Audio output device: iec958 (ALSA)
Passthrough output device: iec958 (ALSA)
It used to work under XBMC Dharma on the same hardware, but don't remember the settings.
In the log there are some entries like this:
So it looks like a PulseAudio issue? I found some older threads regarding this, but many of them are related to former XBMC versions.
As soon as I disable crossfading everything works fine.
Would be nice if you could pull me in the right direction
My audio settings:
22:17:02 T:3016886032 ERROR: PulseAudio: Failed to connect context
