Full Version: Problem skipping/advancing on TS recording
Hi there,
I posted this content on github (under issues), but apparently thats not the way to deal with bugs. I was pointed towards the forum to report bugs. So here goes.
https://github.com/xbmc/xbmc/issues/1592
I am using git 3.3.16~gaa5c84e TVHeadend on a QNAP NAS. The recording completed fine (according to TVHeadend). I am using 1.99.1 Generic OpenElec for the XBMC box.
Everynow and then a successful TS recording will play from start to finish in XBMC, but will bail out from playback when you click "skip ahead" or "advance". The file documented below will play fine from start to finish if I dont skip ahead in XBMC.
I'm not sure if this is a bug in XBMC when playing back TS (over NFS), or if there is something wrong with the TS output file from TVHeadend. Hopefully someone who knows this area of XBMC can shed some light.
The log at crash for XBMC is here (line 201, time slice 21:16:22 is where i clicked to skip ahead)
http://pastebin.com/kxg9xN57
The TSInfo for the recorded file is
Reading from \\192.168.1.100\Multimedia\Recordings\The X Factor\The X Factor.2012-10-09.ts
Scanning 10000 TS packets
Packet 2 is PAT
Program list:
    Program 1 -> PID 0400 (1024)
Packet 903 is PMT with PID 0400 (1024)
  Program 1, version 0, PCR PID 0401 (1025)
  Program streams:
    PID 0401 (1025) -> Stream type 02 (  2) H.262/13818-2 video (MPEG-2) or 11172-2 constrained video
    PID 0402 (1026) -> Stream type 04 (  4) 13818-3 audio (MPEG-2)
        ES info (6 bytes): 0a 04 65 6e 67 00
        Languages: eng
Found 22 PAT packets and 10 PMT packets in 10000 TS packets
The file recorded has these properties in mediainfo (it recorded successfully by TVHeadend)
General
Complete name : \xxx.xxx.xxx.xxx\Multimedia\Recordings\The X Factor\The X Factor.2012-10-09.ts
Format : MPEG-TS
File size : 3.50 GiB
Duration : 1h 30mn
Overall bit rate mode : Variable
Overall bit rate : 5 530 Kbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Codec ID : 2
Duration : 1h 30mn
Bit rate mode : Variable
Bit rate : 4 998 Kbps
Maximum bit rate : 15.0 Mbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.482
Stream size : 3.16 GiB (90%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 4
Duration : 1h 30mn
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : -119ms
Stream size : 166 MiB (5%)
Language : English
Hi there,
Seems everyone has as much idea as me Smile
I have three files in my sample set, two are fine at advancin/skipping, and one fails
I have generated a mediainfo for all three, and the only difference (apart from small numerical changes) is one line missing in the file that fails to advance/skip
Format settings, GOP : M=3, N=12
The two files that work have this line, and the one that fails does not.
Does this provide anyone any clues?
Cheers,
Nathan
It's a known issue and we are discussing possible solutions.
Ah, excellent... I'm not crazy, and it is a known problem.... thanks for the reply.... i seem to remember testing (or trying to test) some frodo builds for a similar problem to this one a while back.... if you need someone to test anything, please let me know. Cheers Nathan
(2012-10-12, 16:36)FernetMenta Wrote: [ -> ]It's a known issue and we are discussing possible solutions.
FYI
I am experiencing the same issues on playing back recordings. Using nightly builds with the DVBLink server backend.
Mysticpete
