(2012-10-20, 15:52)mikrohard Wrote: [ -> ]What changed files? If you have a patch for this then make a PR to the xbmc master branch.
There are multiple files which have to change
GUIWindowVisualision::OnAction
case REMOTE_0:
case REMOTE_1:
case REMOTE_2:
case REMOTE_3:
case REMOTE_4:
case REMOTE_5:
case REMOTE_6:
case REMOTE_7:
case REMOTE_8:
case REMOTE_9:
if (g_application.CurrentFileItem().IsLiveTV())
CPVRChannelPtr channel;
int iChannelNumber = -1;
g_PVRManager.GetCurrentChannel(channel);
if (action.GetID() == REMOTE_0)
iChannelNumber = g_PVRManager.GetPreviousChannel();
if (iChannelNumber > 0)
CLog::Log(LOGDEBUG, "switch to channel number %d", iChannelNumber);
else
CLog::Log(LOGDEBUG, "no previous channel number found");
else
int autoCloseTime = g_guiSettings.GetBool("pvrplayback.switchautoclose") ? 1500 : 0;
CStdString strChannel;
strChannel.Format("%i", action.GetID() - REMOTE_0);
if (CGUIDialogNumeric::ShowAndGetNumber(strChannel, g_localizeStrings.Get(19000), autoCloseTime) || autoCloseTime)
iChannelNumber = atoi(strChannel.c_str());
if (iChannelNumber > 0 && iChannelNumber != channel->ChannelNumber())
CPVRChannelGroupPtr selectedGroup = g_PVRManager.GetPlayingGroup(channel->IsRadio());
CFileItemPtr channel = selectedGroup->GetByChannelNumber(iChannelNumber);
if (!channel || !channel->HasPVRChannelInfoTag())
return false;
OnAction(CAction(ACTION_CHANNEL_SWITCH, (float)iChannelNumber));
return true;
break;
case ACTION_CHANNEL_SWITCH:
if (g_application.m_pPlayer != NULL && g_application.m_pPlayer->OnAction(action))
return true;
break;
Application:OnAction
// first check whether we're within 3 seconds of the start of the track
if (IsPlayingAudio() && m_pPlayer && m_pPlayer->OnAction(action))
return true;
// next : play next song from playlist
if (action.GetID() == ACTION_NEXT_ITEM)
return true;
GUIDialogMusicOSD.cpp
bool CGUIDialogMusicOSD::OnAction(const CAction &action)
if (action.GetID() == ACTION_NEXT_ITEM || action.GetID() == ACTION_PREV_ITEM)
// these could indicate next chapter if video supports it
return true;
return CGUIDialog::OnAction(action);
Als the musicOSD.xml has some changes.
