Hello, I need some help in adding custom playlists to my channels. I created 4 smart playlists with each kids favorite shows etc and that is working fine. when I go to channel configuration, the first channel I add first kid and works fine, then second kid and fine but once I get to third or forth channel and try to add the other two playlists, it just shows a blank and doesn't add it. I'm doing this on an Apple tv 1st gen if it makes any difference.
Bump. I have this same issue: I've created smart playlists that work fine, but when I try to add them as custom playlists in Pseudotv, only the first one works, the rest show up as blank.
and I'm on a Mac Mini, running 10.8, and using Eden.
Durr, that didn't take long to fix myself. Hopefully this will help the OP and others.
I decided to find the playlist files (located in /XBMC/Userdata/Playlists/Video) and open them up in textedit to see what was the difference between the working one and the others.
Here's what the working one said:
<name>80s</name>
And all the others:
<name></name>
So I typed in the name manually, saved the file, and sure enough, it now adds in Pseudotv.
The end. Happy Tv-ing!
