Full Version: Universal artist scraper
So, i wiped XBMC, just for fun (had to rescrape anyway for banners).
Setting up again went ok for the most part. Except i am not getting fanart backgrounds in music library.
I know it worked an hour ago, so code is there. But is the Universal artist scraper supposed to get these?
If not, can i add whatever add-on that is needed for this directly to the skin?
I don't want users to have grab an add-on for this. And will it still update if added to the skin?
What do you mean code is there ?
What if you try to get fanart via artist info ? Checked the scraper settings ?
I meant the code in the skin. Actually both ListItem.Property(fanart_image) and ListItem.Art(fanart).
Scraper settings
Enable Artist Fanarts from fanart.tv
Enable Artist Fanarts from HTbackdrops.com
Both enabled (as i believe is default). Actually everything is enabled and set either to lastfm or musicbrainz.
Going to artists, i see names. Query for all artists does a 1 sec toast attempt.
Artist information, shows searching artist notification. Then comes with a "enter artist name" keyboard popup.
Choosing done on the keyboard causes it to re-appear. Nothing seems to be found.
In songs I am seeing album art, but that is all embedded in the music files.
Relevant debug:
14:28:23 T:3004   DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
14:28:23 T:3004   DEBUG: DialogProgress::StartModal called
14:28:23 T:3004   DEBUG: ------ Window Init (DialogProgress.xml) ------
14:28:23 T:3004    INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
14:28:24 T:4596  NOTICE: Thread CMusicInfoScraper start, auto delete: false
14:28:24 T:4596   DEBUG: ADDON::CScraper::FindArtist: Searching for 'Akon' using Universal Artist Scraper scraper (file: 'C:\Users\user\AppData\Roaming\XBMC\addons\metadata.artists.universal', content: 'artists', version: '2.1.7')
14:28:24 T:4596   DEBUG: scraper: CreateArtistSearchUrl returned <url>http://search.musicbrainz.org/ws/2/artist/?fmt=xml&query=artist:Akon&limit=100</url>
14:28:24 T:4596   DEBUG: CurlFile::Open(0DC94040) http://search.musicbrainz.org/ws/2/artist/?fmt=xml&query=artist:Akon&limit=100
14:28:24 T:4596    INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://search.musicbrainz.org
14:28:25 T:4596   DEBUG: scraper: GetArtistSearchResults returned <results></results>
14:28:25 T:4596   DEBUG: Thread CMusicInfoScraper 4596 terminating
14:28:25 T:3004    INFO: Loading skin file: DialogKeyboard.xml, load type: KEEP_IN_MEMORY
14:28:25 T:3004   DEBUG: ------ Window Init (DialogKeyboard.xml) ------
14:28:25 T:3004   DEBUG: CAnnouncementManager - Announcement: OnInputRequested from xbmc
14:28:25 T:3004   DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputRequested
14:28:27 T:3004   DEBUG: ------ Window Init (Pointer.xml) ------
14:28:27 T:3004   ERROR: Control 1 in window 10099 has been asked to focus, but it can't
14:28:29 T:3004   DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
14:28:30 T:3004   DEBUG: ------ Window Deinit (DialogKeyboard.xml) ------
14:28:30 T:3004   DEBUG: CAnnouncementManager - Announcement: OnInputFinished from xbmc
14:28:30 T:3004   DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputFinished
14:28:30 T:4716  NOTICE: Thread CMusicInfoScraper start, auto delete: false
14:28:30 T:4716   DEBUG: ADDON::CScraper::FindArtist: Searching for 'Akon' using Universal Artist Scraper scraper (file: 'C:\Users\user\AppData\Roaming\XBMC\addons\metadata.artists.universal', content: 'artists', version: '2.1.7')
14:28:30 T:4716   DEBUG: scraper: CreateArtistSearchUrl returned <url>http://search.musicbrainz.org/ws/2/artist/?fmt=xml&query=artist:Akon&limit=100</url>
14:28:30 T:4716   DEBUG: CurlFile::Open(0365D8A0) http://search.musicbrainz.org/ws/2/artist/?fmt=xml&query=artist:Akon&limit=100
14:28:30 T:4716   DEBUG: scraper: GetArtistSearchResults returned <results></results>
14:28:30 T:4716   DEBUG: Thread CMusicInfoScraper 4716 terminating
14:28:30 T:3004   DEBUG: ------ Window Init (DialogKeyboard.xml) ------
14:28:30 T:3004   DEBUG: CAnnouncementManager - Announcement: OnInputRequested from xbmc
14:28:30 T:3004   DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputRequested
14:28:33 T:3004   DEBUG: Keyboard: scancode: 50, sym: 0112, unicode: 0000, modifier: 0
14:28:33 T:3004   DEBUG: CApplication::OnKey: down (f081) pressed, trying keyboard action 61569
14:28:33 T:3004   DEBUG: ------ Window Deinit (Pointer.xml) ------
14:28:34 T:4568   DEBUG: Thread Jobworker 4568 terminating (autodelete)
14:28:34 T:4872   DEBUG: Thread Jobworker 4872 terminating (autodelete)
14:28:34 T:4852   DEBUG: Thread Jobworker 4852 terminating (autodelete)
14:28:34 T:3120   DEBUG: Thread Jobworker 3120 terminating (autodelete)
14:28:34 T:3004   DEBUG: Keyboard: scancode: 4b, sym: 0114, unicode: 0000, modifier: 0
14:28:34 T:3004   DEBUG: CApplication::OnKey: left (f082) pressed, trying keyboard action 61570
14:28:35 T:3004   DEBUG: Keyboard: scancode: 4d, sym: 0113, unicode: 0000, modifier: 0
14:28:35 T:3004   DEBUG: CApplication::OnKey: right (f083) pressed, trying keyboard action 61571
14:28:37 T:3004   DEBUG: ------ Window Init (Pointer.xml) ------
14:28:37 T:3004   ERROR: Control 1 in window 10099 has been asked to focus, but it can't
14:28:41 T:3004   DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
14:28:42 T:3004   DEBUG: ------ Window Deinit (DialogKeyboard.xml) ------
14:28:42 T:3004   DEBUG: CAnnouncementManager - Announcement: OnInputFinished from xbmc
14:28:42 T:3004   DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputFinished
14:28:42 T:4252  NOTICE: Thread CMusicInfoScraper start, auto delete: false
14:28:42 T:4252   DEBUG: ADDON::CScraper::FindArtist: Searching for 'Akon' using Universal Artist Scraper scraper (file: 'C:\Users\user\AppData\Roaming\XBMC\addons\metadata.artists.universal', content: 'artists', version: '2.1.7')
14:28:42 T:4252   DEBUG: scraper: CreateArtistSearchUrl returned <url>http://search.musicbrainz.org/ws/2/artist/?fmt=xml&query=artist:Akon&limit=100</url>
14:28:42 T:4252   DEBUG: CurlFile::Open(0DC94040) http://search.musicbrainz.org/ws/2/artist/?fmt=xml&query=artist:Akon&limit=100
14:28:42 T:4252   DEBUG: scraper: GetArtistSearchResults returned <results></results>
14:28:42 T:4252   DEBUG: Thread CMusicInfoScraper 4252 terminating
14:28:42 T:3004   DEBUG: ------ Window Init (DialogKeyboard.xml) ------
14:28:42 T:3004   DEBUG: CAnnouncementManager - Announcement: OnInputRequested from xbmc
14:28:42 T:3004   DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputRequested
14:28:45 T:3004   DEBUG: Keyboard: scancode: 01, sym: 001b, unicode: 001b, modifier: 0
14:28:45 T:3004   DEBUG: CApplication::OnKey: escape (f01b) pressed, trying keyboard action 61467
14:28:45 T:3004   DEBUG: ------ Window Deinit (Pointer.xml) ------
14:28:45 T:3004   DEBUG: ------ Window Deinit (DialogKeyboard.xml) ------
14:28:45 T:3004   DEBUG: CAnnouncementManager - Announcement: OnInputFinished from xbmc
14:28:45 T:3004   DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputFinished
14:28:46 T:3004   DEBUG: ------ Window Deinit (DialogProgress.xml) ------
Found problem, i believe:
http://forum.xbmc.org/showthread.php?tid...pid1203817
But of course i can't rollback because i wiped everything. And oh great, i also wiped some photoshop files i still needed...
That made my day.
Just use another scraper or?
Yeah, no. It's fine. Wanted to test what worked "out of the box".
It's just my test setup, so no biggy. Was just chasing ghosts until i saw it was the scraper.
(2012-10-12, 16:44)MassIV Wrote: [ -> ]Was just chasing ghosts until i saw it was the scraper.
Smile
