Full Version: Audio-Problem
I have a mainboard with ALC892-Audio. The optical port is connected to a "Teufel Decoder Station 3" (Dolby Digital/DTS Deocer).
The sound in XBMC works fine, both the menu sounds and the 5.1 Dolby-sound of a TV show.
However when I start playing a file with Dolby-Sound and XBMC switches from the menu-sound to Dolby Sound I hear a short noise/crackle-sound.
It's really annoying and probably not good for the loudspeaker.
How can I avoid this?
EDIT: Playing two files fast enough one after another I don't have the crackle. But waiting too long between the playbacks, I will get the crackle when switching again from menu-sound to Dolby-sound.
Disable menu sound from settings and try.
The workaround ... works Smile
But it would be nice to know if it's an XBMC-issue or an DecoderStation-issue.
