2012-10-13, 11:54
Hi all. I have an HTPC with 2 outputs. 1st is the LCD monitor connected via DVI to the video card, the 2nd (an LCD TV) connected to Harman Kardon receiver, which in turn, is connected to the LCD TV.
I also have a logitech Harmony One, to turn everything on at once. My HTPC is always on.
My Sharp TV takes a long time from turning on, then switching to HDMI 5. If the Harman receiver turns on before the TV, all sorts of problems will occur. The HDMI audio of HTPC (Windows 7) will still be disabled. If the Harman was turned on before TV, the LCD TV won't turn into extended display mode, instead, it will remain disabled. Lastly, if XBMC doesn't turn on last (the TV set to right input, Harman on), XBMC will turn on at the Primary display (LCD monitor instead of the LCD TV).
How do you solve this problem?
