Full Version: tinyMediaManager - a media manager written in Java (Win/Mac/Linux)
a new version found its way to the update server:
09.12.2012 - Beta - r89
many changes under the hood: added glazedlists so sorting/filtering of the list is faster
advanced sorting and filtering of the list
solved the gaphical bug with drawing of the tabs (thanks to Michael Hagen - developer of JTattoo)
some minor bugfixes
Thanks, great work Smile
Any chance this will be able to manage movie sets (change set thumb and Fanart)
I will put that request to my todo list and check it soon.
I do not work with movie sets (yet), but I will have a look at it Smile
(2012-12-12, 17:34)mlaggner Wrote: [ -> ]I will put that request to my todo list and check it soon.
Great because there isn't any manager that does it yet and doing it via xbmc is not ideal
(2012-12-12, 18:21)saitoh183 Wrote: [ -> ]
Hi. Ember deals with sets (see http://forum.xbmc.org/showthread.php?tid=116941&page=1).
But besides sets, it would be great to have also movie tags management. They are similar, but one movie can only have belong to one set, which now is scrapped from imdb in some cases, while a movie can have several tags. To add a set/tag to a movie, the only thing needed is to add a line to the .nfo file: <set>setname</set> , or <tag>tagname</tag>
I'd love to see tags integrated in the tinyMediaManager!
just pushed version r92 to the update server:
15.12.2012 - Beta - r92
added trailer support (trailer will be scraped, when using tmdb scraper)
greatly reworked settings panel
added genre icons
some smaller bugfixes
Would be great if you could implement a multiple movie id check. So you could clean your Database if you have to much movies Wink
hi empty,
any thoughts how this "duplicate" check should work? in tmm there is a basic duplicate check based on the movie-folder (a folder isn't added twice to the database).
maybe you could guide me how i can add dulicates?
thanks
r93 has been pushed to the update server:
16.12.2012 - Beta - r93
Mac OSX (at least Mountain Lion) users can now start tmm again - please download the new package directly from http://code.google.com/p/tinymediamanage...loads/list
added trailer scraping to the imdb scraper
added option to explicit choose the poster and fanart when "single scrape"
updated credits
minor bugfixes
(2012-12-16, 15:20)mlaggner Wrote: [ -> ]hi empty,
thanks
For example you could check if there exists an imdb/tmdb ID more than once. If so, you could filter the movielist, so only the duplicates were shown.
You could use for example the "Ember Manager" its doing it very well with only one click on a checkbox.
Uploaded with ImageShack.us
just pushed r94 to the update server:
21.12.2012 - Beta - r94
added feedback and bug report form (now its possible to send feedback and bug reports directly from tmm)
added duplicate search
added movie tags
added imdb.de as imdb source (don't expect good results - there are many movies with no plot/tagline; imho plot/title/tagline from tmdb works better)
some minor ui fixes
Small update:
Oracle recently updated Java 7 to 7u10 (Java 7 Update 10) - this fixed the bug which caused tmm to crash after startup.
Now its possible to use tmm in Java 7!
Yep ... work great now with win 7 and java 7 Smile
tmm look better and better , thanks for you work ...
new version on the update server:
06.01.2012 - Beta - r156
changed releasenumber to fit to the svn commit
many changes under the hood (for a better scraper support)
massive ui cleanup (especially for small resolutions)
added scraper selection on search window
added hd-trailers.net for trailer scraping (thx to myron)
added sorttitles for better sorting of the movie list (thx to myron)
added storage of window positions
added possibility to take a local image as fanart/poster
changed theme
improved imdb scraper
fixed a bug where runtime = 0min was being scraped by the imdb scraper
fixed a bug with renaming options
maybe did some more things Wink
temp. fix to activate sorttitles: delete your config.xml
