2012-10-15, 16:44
2012-10-15, 16:52
XBMC does not self update. Only the installed add-ons have that ability.
2012-10-15, 16:52
(2012-10-15, 16:44)snowjim Wrote: [ -> ]Hi,
Im running XBMC 11.0 that is compiled in mars 2012. Will this update itself? Or will I have to do this manually?
BestRegards
Manual
2012-10-15, 20:48
XBMC stable only updates about once a year (not counting bug fix releases, but we didn't do one for v11 this time), so you haven't actually missed out on anything.
2012-10-25, 12:29
(2012-10-15, 20:48)Ned Scott Wrote: [ -> ]XBMC stable only updates about once a year (not counting bug fix releases, but we didn't do one for v11 this time), so you haven't actually missed out on anything.
I have hade alot of problems with XBMC (Aeon skin) freezings (resulting in ctrl+alt+del) on my ZOTAC ZBOX HD-ND22 box but Windows 7 seems to run just fine. Could a update fix this problems or should I switch hardware instead?
The freezings is often in menus but some times movies could freeze also for a couple of sek or crash?
If I should update, is there a settings file I can keep to avoid setting up the system again(subtitle dealys and so on)?
2012-10-25, 12:32
Aeon Nox thread:
http://forum.xbmc.org/showthread.php?tid=141676
2012-10-25, 12:36
(2012-10-25, 12:32)Martijn Wrote: [ -> ]Aeon Nox thread:
But Aeon NOX is updating automaticly as far as I can see so I should have the latest version.
2012-10-25, 12:37
(2012-10-25, 12:36)snowjim Wrote: [ -> ](2012-10-25, 12:32)Martijn Wrote: [ -> ]Aeon Nox thread:
Read latest posts
