2017-09-26, 14:48
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
2017-09-28, 06:27
Hello. I don't know if this a known problem, but the AniDB MOD Movie scrapper doesn't scrape posters and fanart from themoviedb anymore.
It seems it only downloads artwork from the thetvdb entry that is linked to a movie.
2017-10-16, 22:46
Hello. Can anyone help me with this. (I'm new to Kodi)
When a show have a season number in the folder name and filename then it's not working right.
This is OK:
But others naming scheme doesn't seem to work.
I use the AniDB Client TagSystem Rules in the first post for my files. So this is the filename that I want to use:
But that doesn't work.
Here is a part of the log: https://pastebin.com/36Dy4Gbp
This is OK:
V:\TV Series\My Hero Academia Season 2\My Hero Academia (Season 2) - 06 - The Boy Born with Everything [HorribleSubs][www][1920x1080][h264][379906AA].mkv
V:\TV Series\My Hero Academia Season 2\My Hero Academia Season 2 - 06 - The Boy Born with Everything [HorribleSubs][www][1920x1080][h264][379906AA].mkv
2017-10-16, 22:55
Hello @helloWorld2
Forum rules... Please do not post logs in the forum. They need to be posted at a pastebin (google) type site, and the link posted back here.
The reason the shows won't scrape is because you have incorrectly named your shows. See the guide here... http://kodi.wiki/view/Naming_video_files/TV_shows
Should be...
and this would be even cleaner...
or refer to post #1 for alternate naming conventions and requirements
PHP Code:
Should be...
PHP Code:
V:\TV Series\My Hero Academia\Season 2\My Hero Academia S02E06 - The Boy Born with Everything [HorribleSubs][www][1920x1080][h264][379906AA].mkv
PHP Code:
V:\TV Series\My Hero Academia\Season 2\My Hero Academia S02E06.mkv
2017-10-20, 21:21
Hello Karellen,
Thank you for the help.
I want to use the alternate naming conventions in post #1.
What I have been doing wrong is that I didn't copy and paste the tvshowmatching regexp from post #1 in the advancedsettings.xml file, instead I use the tvshowmatching regexp from the Wiki page http://kodi.wiki/view/Anime .
Here is the logging for reference:
Without the tvshowmathcing regexp from post #1
20:48:52.544 T:15376 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'V:\My Hero Academia Season 2\My Hero Academia Season 2 - 01 - That's the Idea, Ochaco [HorribleSubs][www][1920x1080][h264][B100D692].mkv'
20:48:52.544 T:15376 DEBUG: VIDEO::CVideoInfoScanner::OnProcessSeriesFolder - no match for show: 'My Hero Academia Season 2', season: 2, episode: 1.0, airdate: '01/01/1601', title: ''
With the tvshowmatching regexp from post#1
20:56:54.891 T:15168 DEBUG: VideoInfoScanner: No NFO file found. Using title search for 'V:\My Hero Academia Season 2\My Hero Academia Season 2 - 01 - That's the Idea, Ochaco [HorribleSubs][www][1920x1080][h264][B100D692].mkv'
20:56:54.891 T:15168 DEBUG: ADDON::CScraper::GetVideoDetails: Reading episode '186168' using AniDB.net [MOD] scraper (file: 'C:\Users\haile\AppData\Roaming\Kodi\addons\metadata.tvshows.anidb.net.mod', content: 'tvshows', version: '2.4.0')
20:56:54.895 T:15168 DEBUG: scraper: GetEpisodeDetails returned <details><code>186168</code><title>That's the Idea, Ochaco</title><season>1</season><episode>1</episode><runtime>25</runtime>
Anyway, I decided to use brackets for the season.
2017-10-20, 21:48
Hi helloWorld2
Sounds like you have it working now. Thanks for the feedback.
Enjoy
Enjoy
2017-10-21, 12:34
I have another problem. It's about single video file for multiple episodes. The xml output file from the scraper:CreateSearchUrl is not complete. It got cut off. Here is the content of the xml file: https://pastebin.com/7SpYgfNu . It should be like this: https://pastebin.com/uCiJXJJL .
It seems that the VideoInfoScanner does find a episode match and try to add to the tvshow. But I don't see the episodes in my library.
Here is the log: https://pastebin.com/QG07hQb2
Please advice.
Update #1:
The problem above is with my 'test' system: Kodi (17.4 Git:20170822-7fc6da0). Platform: Windows NT x86 32-bit Running on Windows 10.
I have a better result with my 'real' system: Kodi (17.4 Git:7fc6da0). Platform: Linux x86 64-bit Running on LibreELEC (official): 8.1.2 8.2. In this case the episodes get added nicely.
The different that I can find in the logs is that the GetEpisodeList result is different. On the Windows 10 system there is no result and on the LibreELEC there is. Could this be a bug in the Windows version or something else?
Update #2:
So it's not about the video file being a file with multiple episodes. I also try with a single episode file for this show and that also doesn't work. It's because the xml file is not correct. Somehow it got cut off. That's not the case on the LibreELEC system.
Please advice.
Update #1:
Update #2:
2017-10-21, 21:51
I can immediately see they are not named correctly, but it is possible you have a regex to cover that naming convention. I don't know as you did not paste the full debug log.
Also please provide the link to the show at the scraper site.
2017-10-21, 23:29
The file names are indeed custom file names. But that is no problem when using in conjunction with this scraper and the tvshowmatching regexp in post #1.
In the log you could see that the file name is okay because of the episode match:
The multi part episode is also good:
This is where I think the problem lie (on the Windows system):
The result should be like this (on the LibreELEC system):
I did try to delete the cache on the Windows system. But that didn't help.
DEBUG: VideoInfoScanner: Found episode match V:\TV Series\The Karas\The Karas - 1-3 - Overture [niizk][DVD][704x480][h264][6424AB35].mkv (s1e1) [ - ()(\d+)((?:-\d+)*)(?:v\d+)? - [^\\\/]*$]
DEBUG: VideoInfoScanner: Adding multipart episode 3 [^[-_ex]+([0-9]+(?:(?:[a-i]|\.[1-9])(?![0-9]))?)]
15:55:39.546 T:13796 DEBUG: ADDON::CScraper::GetEpisodeList: Searching 'http://api.anidb.net:9001/httpapi?request=anime&client=xbmcscrap&clientver=1&protover=1&aid=2179' using AniDB.net [MOD] scraper (file: 'C:\Users\haile\AppData\Roaming\Kodi\addons\metadata.tvshows.anidb.net.mod', content: 'tvshows', version: '2.4.0')
15:55:39.549 T:13796 DEBUG: scraper: GetEpisodeList returned <episodeguide><chain function="StartDelayLoop">&</chain></episodeguide>
16:25:58.497 T:140597082822336 DEBUG: GetEpisodeList: Searching 'http://api.anidb.net:9001/httpapi?request=anime&client=xbmcscrap&clientver=1&protover=1&aid=2179' using AniDB.net [MOD] scraper (file: '/storage/.kodi/addons/metadata.tvshows.anidb.net.mod', content: 'tvshows', version: '2.4.0')
16:25:58.509 T:140597082822336 DEBUG: scraper: GetEpisodeList returned <episodeguide><episode><title>Overture</title><url cache="2179.xml">35748</url><epnum>1</epnum><season>1</season><id>35748</id><aired>2005-05-28</aired></episode><episode><title>Inferno</title><url cache="2179.xml">35749</url><epnum>2</epnum><season>1</season><id>35749</id><aired>2005-10-29</aired></episode><episode><title>Revive</title><url cache="2179.xml">45038</url><epnum>3</epnum><season>1</season><id>45038</id><aired>2005-11-26</aired></episode><episode><title>Sacrifice</title><url cache="2179.xml">75605</url><epnum>4</epnum><season>1</season><id>75605</id><aired>2007-06-22</aired></episode><episode><title>Engage</title><url cache="2179.xml">80233</url><epnum>5</epnum><season>1</season><id>80233</id><aired>2007-08-03</aired></episode><episode><title>Existence</title><url cache="2179.xml">80234</url><epnum>6</epnum><season>1</season><id>80234</id><aired>2007-08-03</aired></episode><episode><title>Behind The Scenes</title><url cache="2179.xml">64047</url><epnum>1</epnum><season>0</season><id>64047</id><aired></aired></episode><episode><title>Concept Animation Comparison</title><url cache="2179.xml">64048</url><epnum>2</epnum><season>0</season><id>64048</id><aired></aired></episode><episode><title>Japanese Voice Actor Interviews</title><url cache="2179.xml">64049</url><epnum>3</epnum><season>0</season><id>64049</id><aired></aired></episode><episode><title>In The Voice Booth</title><url cache="2179.xml">84831</url><epnum>4</epnum><season>0</season><id>84831</id><aired></aired></episode><episode><title>Rough Cut Excerpt</title><url cache="2179.xml">84832</url><epnum>5</epnum><season>0</season><id>84832</id><aired></aired></episode><episode><title>Opening</title><url cache="2179.xml">184664</url><epnum>101</epnum><season>0</season><id>184664</id><aired></aired></episode><episode><title>Promo</title><url cache="2179.xml">34025</url><epnum>201</epnum><season>0</season><id>34025</id><aired></aired></episode><episode><title>Promo 2</title><url cache="2179.xml">36594</url><epnum>202</epnum><season>0</season><id>36594</id><aired></aired></episode><episode><title>Original Japanese Trailers and TV Spots</title><url cache="2179.xml">84830</url><epnum>203</epnum><season>0</season><id>84830</id><aired></aired></episode><episode><title>The Revelation Trailer</title><url cache="2179.xml">84833</url><epnum>204</epnum><season>0</season><id>84833</id><aired></aired></episode><chain function="StartDelayLoop">&</chain></episodeguide>
2017-10-23, 15:24
Does anyone else have problems getting SourceTags to work? I enable them but they do not load for content like New Game!!. It should return 4-koma but the genre for New Game!! continues to return nothing when I scan it in.
Ok I figured it out it does create it as a tag but is there any way to have source tags as a genre?
2017-10-23, 20:35
Can you explain what Source Tags are
2017-10-24, 01:17
The tags that list what the source for the series was such as original work -> manga -> 4-koma
I found that it does appear to apply this to tags for the series but I want for example 4-koma to be listed as a genre. (which it effectively is anyways, when you watch a series based on a 4-koma you know what to expect)
2017-10-24, 01:34
2017-10-24, 02:04
So I would need to do this manually one at a time to thousands of entries... ?
I feel like even reprogramming the scraper from scratch would take less time.
What I am asking is the scrapper already pulls this data but is not listing it as genre as you would want it to. It appears that the scraper identifies some of the anidb.net tags as genre but not things like what the source is which for anime is a form of genre you could group all anime based on normal manga as different from ones based on 4-koma which are different from original series and ones based on light novels which are also different from ones based on a full novel and they are still different from ones based on a game but still different from ones based on a visual novel and different from ones based on an action game etc. The scraper is not not labeling these tags from ani db as genre as it should.
2017-10-24, 13:05
Ok i found the issue and corrected it. Could we possibly have this added to the official mod as a toggle so we can have the "source" as an option for genre? Below is the fix:
In metadata.common.anidb.net file anidb.xml
After line 503 add:
After line 518 add:
Adding the above code allows you to have things like manga and 4-koma in your genre
After line 503 add:
<xsl:variable name="originalworkid">2609</xsl:variable>
After line 518 add:
<xsl:call-template name="tagfilter">
<xsl:with-param name="tagid" select="$originalworkid"/>
<xsl:with-param name="depth">2</xsl:with-param>
</xsl:call-template>
