2017-11-07, 20:22
Hi, is there a way to make anidb show the japanese name (romaji) instead of the english translated name?
This is a deal breaking for me.
(2012-10-15, 19:34)scudlee Wrote: [ -> ]Support for OPs/EDs, trailers, etc.
OPs/EDs, Trailers, Parodies, Other are now treated as high-valued specials:
OPs/EDs "C": Season 0 Episodes 101-199 (e.g. S00E101)
Trailers "T": Season 0 Episodes 201-299
Parodies "P": Season 0 Episodes 301-399
Other "O": Season 0 Episodes 401-499
These "specials" will always be mapped to the end of the episode list, independent of your settings. I can change this if need be.
Note: This is only fully supported in Frodo builds. Eden will be slightly unpredictable.
Code Geass s00e02 [8.5] [91E0E783]
Code Geass s00e03 [17.5] [AB275594]
Code Geass s00e04 Picture Drama 01
Code Geass s00e05 Picture Drama 02 'Stage 3.25'
Code Geass s00e06 Picture Drama 03 'Stage 6.75'
Code Geass s00e07 Picture Drama 04 'Stage 9.75'
Code Geass s00e08 Picture Drama 05 'Stage 4.33'
Code Geass s00e09 Picture Drama 06 'Stage 8.75'
Code Geass s00e10 Picture Drama 07 'Stage 9.33'
Code Geass s00e11 Picture Drama 08 'Stage 22.25'
Code Geass s00e12 Picture Drama 09 'Stage 23.95'
Code Geass s00e101 OP1-A Clean Version
Code Geass s00e102 OP1-B Clean Version
Code Geass s00e103 OP2-A Clean Version
Code Geass s00e104 OP2-B Clean Version
Code Geass s00e105 OP3 Clean Version
Code Geass s00e106 ED1 Clean Version
Code Geass s00e107 ED2 Clean Version
Code Geass s01e01 'The Day a New Demon Was Born' [FINAL]
Code Geass s01e02 'The White Knight Awakens' [FINAL]
Code Geass s01e03 'The False Classmate' [FINAL]
Code Geass s01e04 'His Name Is Zero' [FINAL]
Code Geass s01e05 'The Princess and The Witch' [FINAL]
Code Geass s01e06 'The Stolen Mask' [FINAL]
Code Geass s01e07 'Attack Cornelia' [FINAL]
Code Geass s01e08 'The Black Knights' [FINAL]
Code Geass s01e09 'Refrain' [FINAL]
Code Geass s01e10 'Guren Dances' [FINAL]
Code Geass s01e11 'Battle for Narita' [FINAL]
Code Geass s01e12 'The Messenger From Kyoto' [FINAL]
Code Geass s01e13 'Shirley At Gunpoint' [FINAL]
Code Geass s01e14 'Geass vs Geass' [FINAL]
Code Geass s01e15 'Cheering Mao' [FINAL]
Code Geass s01e16 'Nunnally Held Hostage' [FINAL]
Code Geass s01e17 'Knight' [FINAL]
Code Geass s01e18 'I Order You, Suzaku Kururugi' [FINAL]
Code Geass s01e19 'Island of the Gods' [FINAL]
Code Geass s01e20 'The Battle for Kyushu' [FINAL]
Code Geass s01e21 'The School Festival Declaration' [FINAL]
Code Geass s01e22 'Bloodstained Euphy' [FINAL]
Code Geass s01e23 'At Least With Sorrow' [FINAL]
Code Geass s01e24 'The Collapsing Stage' [FINAL]
Code Geass s01e25 'Zero' [FINAL]
(2017-11-12, 17:45)ZERO <ibis> Wrote: [ -> ]Something like this should work for you:But as you can see in the attached photos, it does not work ... Why?
Code:Code Geass s00e02 [8.5][91E0E783]
Code Geass s00e03 [17.5][AB275594]
Quote:22:07:44.182 T:139694655915776 DEBUG: VideoInfoScanner: Fetching url 'http://api.anidb.net:9001/httpapi?request=anime&client=xbmcscrap&clientver=1&protover=1&aid=4521' using AniDB.net scraper (content: 'tvshows')You're not using the MOD scraper, you're using the original scraper.
Quote:New anime-list.xmlBut there it continues to tell me to manually add the rules
The scraper now uses my updated anime-list.xml by default. This list is significantly more complete the the old list, and being actively maintained. (Help very much welcome!)
Quote:AniDB Client TagSystem RulesBut what confuses me even more is after the following instructions, what am i suppose to do? just close out of the AniDB client and refresh my sources?
Version 1.1.0
(Full version) http://pastebin.com/raw.php?i=MkswMaME
(Unformatted) http://pastebin.com/raw.php?i=9dgzsZKB
The Full version is too large to save in the AniDB client, but contains explanations and alternatives for each step, so only use it to modify the Unformatted version to your preferences.
To use these rules you'll need to have an account on AniDB, and then go to the AniDB Client and in the options press "Go Advanced" and then enable Filemoving and Filerenaming, using the Tagging System for both. Then edit the Tagging System, deleting the original content and pasting in the contents of the link above.
Quote:You'll first need to edit the BaseTVShowPath and BaseMoviePath variables to point to their respective folders, and you can also edit the FileInfo variable to however you like it.
(2017-12-31, 08:32)heatl0rd Wrote: [ -> ]I am a little confused at the instructions.Yes.
Do i simply install the repo and the moded ani db scapper thorough the repo and just add my sources?
Quote:Or am i suppose to login to the anidb website and use this client java program in addition to the above?Entirely optional. Using the client (with the renaming rules) just ensures everything is named perfectly for the scraper to be 100%(ish) accurate.
Quote:I get confused because of the following. Which implies i dont need to manually add the rules!?This is unrelated. The mapping list is used by the scraper to provide episode plots and artwork from tvdb. It's not something you really need to be concerned with.
Quote:But there it continues to tell me to manually add the rulesIf you look at the top two lines of the rules, you'll see two variables called "BaseTVShowPath" and "BaseMoviePath", change the values of them to be where you want your files to be placed.
[snip]
(2018-01-01, 18:28)amornik Wrote: [ -> ]Hey guys,I have problem with this scraper as well it just doesn't work properly no matter what way you rename a file. Just use Shoko Server and Nakamori works perfectly way less fuss than this
looked around a bit but couldn't find help.
for some reason I cant get Kodi to show me shows such as stiens gate or psycho mob 100. I have them, the file names are sorted, but they won't show.
wondering if i'm doing something wrong here. using the latest kodi and anidb.net addon.
1. is there a way to manually make the addon show a show? not scapre, or something similar?
2. anyone else have issues with these 2 shows? anything else I can do?
thanks!
