2013-09-20, 03:54
Pages: 1 2
2013-09-20, 14:59
How and where did you fix the permissions?
2013-09-20, 17:24
(2013-09-20, 14:59)kwirk Wrote: [ -> ]How and where did you fix the permissions?You fix permissions in OS X through Disk Utility application, then select the hard drive and click Check permissions or Repair permissions
I'm still sorting this audio issue out. Haven't been behind my mini is a few days. All my settings (apart from skin, which I have now reset to Confluence) were as they should be according to Memphiz's suggestions. Played a show earlier today without audio problems (but I had to boot up my entire mini, so no surprise there), will see how audio behaves when I start it up again from sleep later this evening. Will try permissions if all else fails, and report back later...
2013-09-21, 18:15
Thanks for your answer.
but it did not help...
I think it got worse with the last osx update
2013-09-26, 21:14
Sorry it took some time, but I finally managed to spend some time behind the TV again. The bad news: audio issue still not resolved despite setting the audio as per Mamphiz's suggestion, and despite fixing permissions on my HDD...
I still have to toggle the speaker channels through the entire list of options, and when I reach 2.0 I start to hear system sounds again.
XBMC also still has playback issues on several (but not all) mkv video files - image will stutter without audio, and I cannot fix this issue no matter what. These files will play without issue on my jailbroken AppleTV2 through the Infuse program. I have installed XBMC on the Apple TV, but it's horribly slow going...
2013-10-17, 00:11
the last update of mac osx was the solution.
Audio works again after sleep now!
Pages: 1 2
