Full Version: ALT + TAB To web browser?
i am trying to authenticate with getglue in a plugin, wich opens up a browser window.
The problem is, how do i switch to that window? Or ALT+Tab if you like...
Can someone please help? Rolleyes
See image:
https://www.dropbox.com/s/joippl3f442c6u....43.33.jpg
Anyone?
You can open the browser by using Advance Launcher.
http://forum.xbmc.org/showthread.php?tid...pid1172733
I already done it and Chrome is opening like in your picture.Only having some issues.
First, Chrome does not open full screen.You can solved this by following next steps:
http://setupguides.blogspot.nl/2012/03/l...en-in.html
Already done this but unfortunately sound does not work.It can be solved by using PulseAudio Volume Control.
Somehow I can find this on my XBMCBuntu system. If I want to download it it say i already have latest version installed Huh
Second problem I have is Overscan.Nvidia software does no longer as the option to change this.
So i need to do this by hand, but being a Linux N00b thinks are not going fast
