Full Version: Xwmm movie set within movie set
Hi
I wonder if anyone can help on how I can create a movie set within a movie set using xwmm. What I have is a movie set labeled music where I keep all my music DVDs to separate them from my movie DVDs. Some of my music DVDs though are multiple discs. What I ideally want is one DVD poster within the movie set that I click on and that will open up a new movie set so I can select the right disc.
I can't find an obvious answer so does anyone have a solution.
Iain
you can't
only one level of sets allowed
Thanks - are there any alternatives to xwmm that I could use to create this structure?
(2012-10-17, 22:19)whitts1 Wrote: [ -> ]Thanks - are there any alternatives to xwmm that I could use to create this structure?
no because XBMC only allows one level.
XBMC Frodo will supports 'tags' so you can tag them
I've just had a look at the tag info on frodo development.
Am I right in thinking that I can create a new tag called say "Gary Moore Montreux" and add all the discs for this set to the tag. Then the tag will show up in the movie library with poster, fanart and info. That tag can then be added to a movie set using xwmm.
