Full Version: Home page multiple rss feed display
i'm trying to configure multiple rss streams to display on the home page with the lateset xbmc cvs, however when i configure the skin and main .xml my xbox locks on boot.
i did'nt have this problem with earlier cvs versions, and was wondering if there may currently be a conflict or revised change to the .xml that is now needed.
i listed the rss contols i'm susing below and the xbmc log.
please advise of a solution.
thanks for any advice, and especially thanks for all your hard work in providing an excellent app.
xboxmediacenter.xml
Quote:<rss>
   <set id="1">
     <feed updateinterval="30">http://www.xbox-scene.com/xbox1data/xbox-scene.xml</feed>
   </set>
   <set id="2">
     <feed updateinterval="30">http://rss.news.yahoo.com/rss/topstories</feed>
   </set>
   <set id="3">
     <feed updateinterval="30">http://rss.news.yahoo.com/rss/hurricanes</feed>
   </set>
 </rss>
home.xml
please note that if the <id> tags are all the same number, it will not stream the different url sets, it will just stream the same url set 1 for all displays. when i change the <id> to a different number, thats when xbmc will crash upon boot.
Quote:    <control>
     <description>rss feed</description>
     <type>rss</type>
     <id>1</id>
     <posx>0</posx>
     <posy>470</posy>
     <width>720</width>
     <font>font13</font>
     <urlset>1</urlset>
     <titlecolor>ffd2ff00</titlecolor>
     <headlinecolor>ddced8da</headlinecolor>
     <textcolor>ffd2ff00</textcolor>
   </control>
   <control>
     <type>rss</type>
     <id>2</id>
     <posx>0</posx>
     <posy>490</posy>
     <width>720</width>
     <font>font13</font>
     <urlset>2</urlset>
   </control>
   <control>
     <type>rss</type>
     <id>3</id>
     <posx>0</posx>
     <posy>510</posy>
     <width>720</width>
     <font>font13</font>
     <urlset>3</urlset>
   </control>
xbmc log
Quote:16-08-2005 09:57:35 notice q is mapped to:harddisk0\partition6\apps\xbmc
16-08-2005 09:57:35 notice starting xboxmediacenter.  built on aug 16 2005
16-08-2005 09:57:35 debug setting resolution 4
16-08-2005 09:57:35 debug we set resolution 4
16-08-2005 09:57:35 info load language file:q:\language\english\strings.xml
16-08-2005 09:57:35 notice loaded q:\system\players\mplayer\iso639-1.xml
16-08-2005 09:57:35 notice loaded q:\system\players\mplayer\iso639-2.xml
16-08-2005 09:57:35 info load keymapping
16-08-2005 09:57:35 info loading q:\keymap.xml
16-08-2005 09:57:35 info checking skin version of: project mayhem iii
16-08-2005 09:57:35 info skin version is: 1.3
16-08-2005 09:57:35 info  gui format 720x480 ntsc 4:3
16-08-2005 09:57:35 info  gui screen offset (0,0)
16-08-2005 09:57:35 info install unhandled exception filter
16-08-2005 09:57:35 info creating subdirectories
16-08-2005 09:57:35 info   thumbnails folder:q:\thumbs
16-08-2005 09:57:35 info   shortcuts folder:q:\shortcuts
16-08-2005 09:57:35 info   albums folder:q:\albums
16-08-2005 09:57:35 info   recording folder:q:\recordings
16-08-2005 09:57:35 info   screenshots folder:q:\screenshots
16-08-2005 09:57:35 info   subtitle folder:q:\subtitles
16-08-2005 09:57:35 notice found memory unit in port 2 (bottom), mounted as: i:
16-08-2005 09:57:35 notice initialize assignment:[dash] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
16-08-2005 09:57:35 warning not initializing network, using settings as they are setup by dashboard
16-08-2005 09:57:35 info init network
16-08-2005 09:57:35 info get local ip address:
16-08-2005 09:57:39 info ip adres:192.168.1.100
16-08-2005 09:57:39 notice xbfilezilla: starting...
16-08-2005 09:57:39 notice xbfilezilla: started
16-08-2005 09:57:39 notice start led control
16-08-2005 09:57:39 notice dim lcd on playback
16-08-2005 09:57:39 notice checking the date!
16-08-2005 09:57:39 notice - current date is: 16-8-2005
16-08-2005 09:57:39 notice start dvd mediatype detection
16-08-2005 09:57:39 notice initializing playlistplayer
16-08-2005 09:57:39 info lcd not used
16-08-2005 09:57:39 notice start fancontroller
16-08-2005 09:57:39 notice load default skin:[project mayhem iii]
16-08-2005 09:57:39 info   load skin from:q:\skin\project mayhem iii
16-08-2005 09:57:39 info   delete old skin...
16-08-2005 09:57:39 info default 4:3 resolution directory is q:\skin\project mayhem iii\pal
16-08-2005 09:57:39 info default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
16-08-2005 09:57:39 info skin version is: 1.3
16-08-2005 09:57:39 info   load fonts for skin...
16-08-2005 09:57:39 info loading fonts from q:\skin\project mayhem iii\ntsc\font.xml
16-08-2005 09:57:39 info load font:font13 path:q:\skin\project mayhem iii\fonts\common-font13.xpr
16-08-2005 09:57:39 info load font:font14 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
16-08-2005 09:57:39 info load font:matrix8 path:q:\skin\project mayhem iii\fonts\matrix8.xpr
16-08-2005 09:57:39 info load font:font04 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
16-08-2005 09:57:39 info load font:font12 path:q:\skin\project mayhem iii\fonts\common-font12.xpr
16-08-2005 09:57:39 info load font:font10 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
16-08-2005 09:57:39 info load font:fontkb path:q:\skin\project mayhem iii\fonts\common-font13.xpr
16-08-2005 09:57:39 info load font:font101 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
16-08-2005 09:57:39 info load font:special12 path:q:\skin\project mayhem iii\fonts\special-normal.xpr
16-08-2005 09:57:39 info load font:special13 path:q:\skin\project mayhem iii\fonts\special-bold.xpr
16-08-2005 09:57:39 info load font:fontbl path:q:\skin\project mayhem iii\fonts\common-font10.xpr
16-08-2005 09:57:39 info   load new skin...
16-08-2005 09:57:39 info loading skin file: home.xml
16-08-2005 09:57:39 info loading references file: q:\skin\project mayhem iii\ntsc\references.xml
16-08-2005 09:57:39 info loading user windows q:\skin\project mayhem iii\pal\custom*.xml
16-08-2005 09:57:39 info loading skin file: q:\skin\project mayhem iii\pal\custom1.xml
16-08-2005 09:57:39 info loading skin file: q:\skin\project mayhem iii\pal\custom3.xml
16-08-2005 09:57:39 info loading skin file: q:\skin\project mayhem iii\pal\custom4.xml
16-08-2005 09:57:39 info loading skin file: q:\skin\project mayhem iii\pal\custom5.xml
16-08-2005 09:57:39 info   initialize new skin...
16-08-2005 09:57:39 info loading skin file: pointer.xml
16-08-2005 09:57:39 info loading skin file: musicoverlay.xml
16-08-2005 09:57:39 info loading skin file: videooverlay.xml
16-08-2005 09:57:39 info loading skin file: dialogvolumebar.xml
16-08-2005 09:57:39 info loading skin file: dialogseekbar.xml
16-08-2005 09:57:39 info loading skin file: dialogkaitoast.xml
16-08-2005 09:57:39 info loading skin file: dialogmutebug.xml
16-08-2005 09:57:39 info loading q:\skin\project mayhem iii\sounds\sounds.xml
16-08-2005 09:57:39 info   skin loaded...
16-08-2005 09:57:39 info kaiclient: instantiating...
16-08-2005 09:57:39 debug udpclient: creating udp socket...
16-08-2005 09:57:39 debug udpclient: setting broadcast socket option...
16-08-2005 09:57:39 debug udpclient: setting non-blocking socket options...
16-08-2005 09:57:39 debug udpclient: spawning listener thread...
16-08-2005 09:57:39 debug udpclient: ready.
16-08-2005 09:57:39 info kaiclient: ready.
16-08-2005 09:57:39 notice kaiclient: discovering kai engine via udp broadcast.
16-08-2005 09:57:39 info detecting dvd-rom media filesystem...
16-08-2005 09:57:39 info cd analysis report
16-08-2005 09:57:39 info activating window id: 10000
16-08-2005 09:57:39 info ____
16-08-2005 09:57:39 info cd-rom with udfx filesystem
16-08-2005 09:57:39 info tracks overall:1; audio tracks:0; data tracks:1
16-08-2005 09:57:39 info using protocol d:\
16-08-2005 09:57:39 info removing tempfiles
16-08-2005 09:57:39 info disc label:
16-08-2005 09:57:39 info checking bookmarks for special directories
16-08-2005 09:57:39 notice initialize done
16-08-2005 09:57:39 notice running the application...
16-08-2005 09:57:39 fatal exception_access_violation (0xc0000005)
at 0x009f2f50
at 0x009f2f50
if everything is ok with the default home.xml, try changing the ids for the rss controls in home.xml to 10001, 10002, and 10003.
(kraqh3d @ aug. 17 2005,16:49 Wrote:if everything is ok with the default home.xml, try changing the ids for the rss controls in home.xml to 10001, 10002, and 10003.
that worked, thanks.
no problem. you were duplicating ids. if you're adding brand new controls to a window, make sure that they have a unique id's.
