Full Version: Album with multiple discs
Hi All,
Firstly, I'm loving the reFocus skin, finally getting round to looking at it properly, tweaking the settings and such.
I'm trying to organise my music library and have used MusicBrainz and Clementine to tidy up some tags.
However, I'm having an issue with Albums that have multiple discs. Is there no way to group these like Seasons in TV shows. So you select the album, then the disc?
As far as I can tell, I can either name the Album Tag with the disc number in so the tracks get listed per disc (but clutters up the interface) or give all tracks the same album name, then they all appear in the same big list.
Any help/advice on how to organise my music would be much appreciated.
Dex
Some tag editors allow you to set the disc number.
I use tagscanner, witch support that tag
I use mp3tag, it is very easy and a free tool.
CD1 and CD2 are displayed in the same list and can not be displayed as two separate sublists of the album
