i should add that i have only two options when changing the resolution settings: ntsc 4:3 and auto. of course only when i use the standard cable... when i use the hdtv cable everytime i change the resolution- crash. the log says:
17-08-2005 01:24:34 notice starting...
17-08-2005 01:24:34 notice q is mapped to:harddisk0\partition1\apps\xbmc
17-08-2005 01:24:34 notice load settings...
17-08-2005 01:24:34 notice loading t:\settings.xml
17-08-2005 01:24:34 info parsing <profiles> tag
17-08-2005 01:24:34 info calibration for 1080i 16:9 1920x1080
17-08-2005 01:24:34 info subtitle yposition:1042 pixelratio:1.000 offsets
0,0)->(1920,1080) osdyoffset:0
17-08-2005 01:24:34 info calibration for 720p 16:9 1280x720
17-08-2005 01:24:34 info subtitle yposition:694 pixelratio:1.000 offsets
0,0)->(1280,720) osdyoffset:0
17-08-2005 01:24:34 info calibration for 480p 4:3 720x480
17-08-2005 01:24:34 info subtitle yposition:432 pixelratio:0.912 offsets
0,0)->(720,480) osdyoffset:0
17-08-2005 01:24:34 info calibration for 480p 16:9 720x480
17-08-2005 01:24:34 info subtitle yposition:463 pixelratio:1.215 offsets
17-08-2005 01:24:34 info calibration for ntsc 4:3 720x480
17-08-2005 01:24:34 info calibration for ntsc 16:9 720x480
17-08-2005 01:24:34 info calibration for pal 4:3 720x576
17-08-2005 01:24:34 info subtitle yposition:518 pixelratio:1.094 offsets
0,0)->(720,576) osdyoffset:0
17-08-2005 01:24:34 info calibration for pal 16:9 720x576
17-08-2005 01:24:34 info subtitle yposition:555 pixelratio:1.459 offsets
17-08-2005 01:24:34 info calibration for pal60 4:3 720x480
17-08-2005 01:24:34 info calibration for pal60 16:9 720x480
17-08-2005 01:24:34 notice getting hardware information now...
17-08-2005 01:24:34 info using analog output
17-08-2005 01:24:34 info ac3 pass through is disabled
17-08-2005 01:24:34 info dts pass through is disabled
17-08-2005 01:24:34 notice checking resolution 10
17-08-2005 01:24:34 notice av pack: hdtv
17-08-2005 01:24:34 notice av flags: 480p
17-08-2005 01:24:34 notice setting autoresolution mode 2
17-08-2005 01:24:34 notice loading q:\xboxmediacenter.xml
17-08-2005 01:24:34 fatal xbappex: could not create d3d device!
17-08-2005 01:24:34 fatal width/height
720x480)
17-08-2005 01:24:34 fatal refreshrate:0
17-08-2005 01:24:34 fatal 4:3
17-08-2005 01:24:34 fatal progressive
17-08-2005 01:24:34 notice running the application...
17-08-2005 01:24:34 error exception in capplication::render()
i realize that the hdtv questions are asked very often... you must be sick of them. please give me a suggestion!
ps: i have tried to google the fatal error message. i found it but it was in swedish (or something like that) and didnt get a reply.
i am really at a loss here, what can i do?
