i use build 8/17(revision 1.1389).
when playing stream file in internet, it can't show percents in cacheing meida files.
everything is ok in build 8/14.
regards,
hibaby
when it starting, or when it runs out of data in the middle of a movie?.. cause i get percentage for when it's caching.. (it doesn't display the numbers yes, but the progressbar moves).. removed the numbers, found them more anoying than anything.. (only whent up to 20% anyways)
(elupus @ aug. 17 2005,17:25 Wrote:when it starting, or when it runs out of data in the middle of a movie?.. cause i get percentage for when it's caching.. (it doesn't display the numbers yes, but the progressbar moves).. removed the numbers, found them more anoying than anything.. (only whent up to 20% anyways)
i see,now i only can't see the number.
but the dialogue arragement is not good enough,the space between "cache..." and progressbar is so wide. :p
