Full Version: Multiple SFTP-paths for TVShows?
I'm trying to set up my laptop with XBMC to be able to (securely) access my media-server (the server is running Debian) over the internet and was trying to get SFTP working. It works well enough for movies that I keep on one drive, but when I try it for TV-series that are spread over multiple drives it just doesn't work. Reading the documentation there seems to be a limitation in XBMC that means you cannot add multiple SFTP-paths for a source (see http://wiki.xbmc.org/index.php?title=Use...ources.xml).
Is there any specific reason why this isn't possible? Is there any way to work around this or should I resort to using SMB/Samba instead (which I would really want to avoid due to security concerns)?
As far as I can tell, there's nothing to suggest that you can't have multiple SFTP paths for a single source. Have you tried this through the GUI in XBMC?
I have tried that. It does scrape everything as it should, but when I run a "clean database" it simply removes all entries.
