Full Version: Skin trouble
I'm currently running 5.0.2 jailbreak on an apple TV 2nd gen.
I changed the skin add-on and now can't do anything.
The add on loads but it wont let me open any thing and thus i can't go back to the previous working add-on.
Any ideas how to get around this problem?
Not sure which skin it is, it's orange and white though.
Thanks in advance.
Thanks for that link.
One thing, how do i -
4.7 Stuck on a bad skin
Shortcut: #SkinChange
If you changed skins and now can't navigate back to change it back, delete /private/var/mobile/Library/Preferences/XBMC/userdata/guisettings.xml
SSH in and use the command:
rm /private/var/mobile/Library/Preferences/XBMC/userdata/guisettings.xml
or use an SFTP client such as Cyberduck (wiki) and navigate to that file and delete it there.
